Question about Hitachi 61SWX10B 61" Rear Projection Television
Hitachi 61iwx10ba Will not turn on
I was hoping some of the people here could help me out. I just got this Hitachi TV that appears to be 4-5 years old. If you try and turn it on, the power light will click between 5-14 times. I say that because sometimes it is 5 and sometimes it is 14. After taking the back cover off, I see the red led light and 2 green led lights. The two green led light appear to be on the center board and the one furthest to the left is blinking. I would appreciate it if someone could point me in the direction of the problem. Unfortunately I am in the process of getting my hands on a maintenance manuel for this, but have not been able to. The fuse by the power supply appears to be good, but I do not know what those other fuses look like that seem to also be problems. Any direction that someone could give me would be helpful.
  • 6 more comments
  • shadowlightz Jun 28, 2008
    Ok here is a little update. I found 5 led lights now. I see the red and the two in the center as before. Just to the left are two more. The third one from the left will not light up at all. The 4th one blinks with the 2nd one. So I get a solid green on the first one. The red one is also solid. The 3rd green LED does not light up at all, and the 4th one looking left blinks with the 2nd one from the left. I can supply pic if needed
  • shadowlightz Jun 29, 2008
    Ok I payed for a troubleshooting guide, but it isn't really helping. It told me to look at the PWB and check the LEDs on it, but the problem is that there is only one, and there should be two. Plus the LED on there doesnt light up. The fuses on the power board are good, and the guide recommends testing the solid state fuses, but doesnt say what they should measure to, or what you should do if they don't.
    I still have the 4 green LEDs. Going from right to left, the first one stays green, the second blinks, the third one stays dark, and the fourth blinks with the second. The red doesnt look like it blinks, but it does seem to pulse with the green LEDs when they blink. Eventually the whole thing shuts off in about 10 seconds.
    So far that hasnt worked
    Any idea which one?
    Would posting a picture help? I haven't been able to identify one that looks burnt. I was mainly zeroing in on the one LED that wasn't doing anything.
  • shadowlightz Jun 30, 2008
    Thanks for the info. Can you tell me where these parts are. I don't see them on the component locater on the service manual I have. So far I have been able to tell that the 2 fuses on the power board have no great amount of power going through them, but the convergence board has about 120 V going through it. Can you give me a picture or something of the route to test on?
  • shadowlightz Jul 01, 2008
    No go on the self diagnostic. Will not go into it.
  • shadowlightz Jul 02, 2008
    Ok I have some information. I have been testing some of the circuits on the deflection PWB board. The third LED (DP37) is burned out. I have tried testing it, and it will not light up. Since it is a diode in the circuit, should I go ahead and replace it? I have also been testing transistors. I am using base, emitter, and collector terminology. I am posting my values on the transistors below. They are being tested via Blue Point DVOM on diode mode with voltage first and ohms second.
    Q777 transistor C56811j2 = B to E = .00 V and .7 ohms
    B to C = .7 climbs to OL and OL Ohms
    E to C = .416 V and OL Ohms
    QH01 transistor 2sk2771 = B to E = .643 V and OL ohms
    E to C = .398 V and OL Ohms
    Q701 transistor FN52110 = B to E = .684 V and OL ohms
    E to C = .542 V and OL Ohms
    So am I correct in assuming that q777 transistor is shorted? And can someone tell me if I have to replace the LED?
  • 4,472 Answers
Ya sounds like it is shorted, replace the led if you think you can and you feel that is a/the problem.
Thanks,
Lee
Posted on Jul 02, 2008
  • 790 Answers
Hi
Can you take a video or picture in your unit... i want to see it clearly then upload here thanks!
    Genius:
  • 1,665 Answers
Following link helps on TV power supply troublshooting
http://www.highlandelectrix.fsnet.co.uk/repair/repair.html
  • 105 Answers
It seems to be shortened somewhere.try to call a technitian and dont try to fix it yoursself because a high voltage is carried at the back
    Master:
  • 638 Answers
Yes its shortened.you first replace the transistor and then see if it does not work properly then replace the led.that will definately help .
and if does not help i will suggest you to get it repaired through a authorized service technician as there the company will charge you but will provide you the minimum warranty of six months.
please rate the solution as fixya if helped by it to solve your problem.wish you good luck.
  • hemant somaiya
    hemant somaiya Jul 07, 2008
    first try to replace transistor dont directly jump onto a decision of changing a led.
  • 144 Answers
Unless you are an experienced TV Service Technician, do not try to fix things by yourself, There are chances of getting fatal electric shocks..
If you have a service manual/ schematic diagram, go for a step by step diagnosis..
1) Check O/P voltages of Power Supply are normal.
2) Check for shorts / open O/P transistors in horizontal & deflection circuits.
3) Check presence of drive on H-O/P transistor' base
4) Try changing the eeprom with a new programmed one.
Its best to go to a good service center & get this one repaired..
Posted on Jul 01, 2008
  • 4,234 Answers
At this point checking for fuses is a waste of time. The set detects a problem and is shutting down. The clicks indicate a number of attempts to start up. Check the following:
1) Check the horizontal output transistor for a shorted condition. If shorted, replace.
2) Check all of the solder connections on the main power supply board and resolder any that appear to be grainy or have rings.
3) Check the solder connections on the convergence ICs. These are large black ICs attached to a heatsink and should be marked STKxxx.
Report back with your results.
Note: The power supply board and the convergence board are still available as replacement parts. One option for you could be to have a detailed repair estimate generated by a local servicer. Taking that info, we can guide you through the actual repair.
Dan
Posted on Jun 30, 2008
    Genius:
  • 2,035 Answers
When it shuts off. Try doing what's called a self-diagnostic test.
As soon as the television shuts try these steps.
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Self Diagnosic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
http://servicemanuals.vstore.ca/
However, be aware that there are voltages inside your TV set that can kill, even if unplugged.
Good luck.............
    Genius:
  • 1,226 Answers
There is shortage in the input power in the TV projection. You can solve this testing voltage regulator in the or from the input power up to the horizontal and vertical projection of the TV. some of this due to busted diode however the most common fault are the capacitor and the regulator.
may this help
melnavz
Posted on Jun 29, 2008
  • Emelio Navaja
    Emelio Navaja Jul 02, 2008
    after identifying the busted parts, do some check in other circuit then replace it. however donot test the unit until such time that all the busted parts has been replace. this will burn out again the new parts.
    melnavz
  • 983 Answers
I think there might be some problem in the transformer ....
or due the over heating some of the capacitor might have burnt out .....
  • 2 more comments
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jun 29, 2008
    just have a look on all circuit boards is there any burnt smell or symbol ....
    try to identify the burnt capacitor ...
    as you have told that the power supply is in good condition so exactly the capacitor is burnt out
    burnt capacitor may be on the power board (if the led s are in the board then check in which board the red light appears)...
  • 6,487 Answers
Check if their is an open resistor around the flyback and horizontal output transistor, if none try checking the jungle IC, it might lock of solder around the pins.
Hope that helps...
I have a 1999 hitachi ultravision 60" projection tv and the power will turn on but minutes later it shuts itself off. How do I correct this problem?
When was the last time the projection lamp was replaced?The projection lamp on the tv now,has not been replaced like a 1 1/2 or 2 years,tv been on and watches like 4 or 5 hours a day?The tv projection lamp life are over.Require a new projection lamp.
Apr 03, 2010 | Hitachi UltraVision 60VF820 TV
Black Lines
Just to reset first before proceed another procedure;
Resetting the TV
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet for 4 - 6 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards,
VOTIT
Oct 07, 2008 | Hitachi 61SWX10B 61" Rear Projection...
Hitachi 51F510 with NO POWER
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Right on schedule since your TV is 10 years old)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Feb 15, 2008 | Hitachi 51F510 51" Rear Projection...
Power light keeps flashing on and off
What make and moel set do you have? Most sets hav a daignosis code built into the flashing power light.
Feb 03, 2008 | Hitachi 46F500 46" Rear Projection...
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Ultrascan hitachi 43" hd tv
Marcus,
What you're describing is convergence and the amps need to be replaced... IK04 and Ik05 are two STK392-110 and Hitachi suggests replacing them with the STK392-150's for greater reliability..
If you're not too capable in electronics this is one to leave for the professionals. But at least you can call around and ask what each shop charges for replacing the convergence amps in this unit...
Hope this helps.
Bill
Nov 14, 2007 | Hitachi 43GX01B 43" Rear Projection...
TV Flickers up and down and screen is shifted to the right w/ red color dominating the screen.
the last hitachi that had this problem i fixed it bad finding bad solder conenctions throughout the board that the convergance ic's are on, also i foind some on the two main board in my repair. hopefully resoldering the convergance foard will fix the jitter or jumping around problem. if the picture is too red you can also try turning down the screen control slightly. good luck
Jan 02, 2007 | Hitachi 51F500 51" Rear Projection...
Chirping noise and flashing front power light.
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Aug 17, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 61SWX10B 61" Rear Projection Television Logo
115 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
