Question about GE Monogram ZISS480DRSS Stainless Steel
GE Monogram freezer not freezing food & refreegiration side not cold enough
Is there
  • 1 more comment
  • ronald t Oct 27, 2008
    Same here...it is freezing meats and making ice but not freezing ce cream and liquids.
  • sylvan2009 Jan 10, 2009
    similar prob ge won't stand behind  and supposedly unit is not repairable and solution is to buy a new $5,000+ unit
  • Anonymous Apr 12, 2009
    My monogram will go along just fine and then all of the sudden it will not freeze anything at the bottom of the freezer. Unfortunately this ruins all the meat. GE's solution was a thousand dollars for a new compressor which did not fix the problem that still exists. GE does not stand behind the product.
    Problem Solver:
  • 13 Answers
First thing to look for is the freezer fan running. then is the air circulating in compartment. blockage is a cause. themostat setting is important.you can leave freezer door open and trigger the door switch.you should feel cold air comming ot. i know it may sound silly check to see if freezer light goes off when shutting door. fan,circulation,cold air input.thermostat,lightoff. good luck
Posted on May 03, 2009
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
My GE Monogram side by side we can't control the refrig side temp. It just freezes no matter what. We have wasted so much food.
its the damper vent door thats located in the upper left area of the refrigerator compartment and this door breaks and then cant shut to close off the cold air from the freezer entering the refrige,general electric has had a bad problem with these damper vent doors,now they have a new and improved or so they say damper vent door,its about $100.00+
May 29, 2011 | GE Monogram Side by Side Refrigerator
My refrigerator won't stay cold. The freezer is working but not the refrig side
I have the GE Monogram ZISB480 side by side. Once again I have your same problem of the freezer freezing (good), but the refrig does not go below 45-50. All the official repair guy did was do a quick 1 hour defrost. I did that also just two weeks ago and it was fine. Now it is not cold enough again. I just looked in the freezer using a mirror I was able to push a 2"x2" trap door open towards the fridge. It must be automated and malfunctioning. Why the heck the repair guy didn't work on that? This week I'll call for another repair job ($85 for him to just come to my door) and ask him to fix the trap door. -Bob
Nov 14, 2010 | GE Monogram Side by Side Refrigerator
GE Monogram won't freeze food
your evaporator coil in the rear area behind the panel is iced up and blocking fan air flow to the freezer compartment
Jul 25, 2010 | GE Refrigerators
GE Monogram freezer will not stay cold enough
This sounds like you freeezer is not defrosting properly causing foods not to freeze rapidly and possibly causing the fresh food section to remain warmer than normal. I think it would be a good idea to unplug and remove the rear panel in the back of your frezzer to examine just what is going on. Hopefully the defrost element part number WR51X322 is not defective. We also will need to inspect the mother control board below your refrigerator and in-closed in a case that covers the board. All defrost is done by this board part number WR55X10560 Look for burn marks and signs of heat damage. If found the board will need replaced. You also can contact me at appliancepartsse@yahoo.com and the parts can be found at these links. Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
GE monogram
I have a Ge Monogram 42" side by side. The temp on both side are not cold enought and I tried to change the temperature setting to colder but it's went right back. All the food started to thawed. PLease help. Thanks
Jun 18, 2008 | Refrigerators
GE Monogram Side by Side 42" Freezer light is lit on front panel.
The defrost timer is what I think you are asking. It is behind a cover near the light, The timer puts the fridge in defrost ever 6 to 8 hours. If the timer is bad it will stop the cycle of defrost and cause the freezer and the cold food section to warm spoiling the food and increase the freezer temp. Try turning the timer screw clockwise until you hear the fridge compressor stop. If after this listen for a crackling noise that will be the sound of defrost taking place. If doing this starts defrost, you will need to replace the timer.
Oct 20, 2007 | GE Monogram ZICS360NRRH C... Bottom...
GE Monogram ZISS480DRSS Stainless Steel Logo
612 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
