Question about KitchenAid Kitchen Ranges
Error code SA 66 - KitchenAid Kitchen Ranges
Error code 66
conflicting info
http://www.obd-codes.com/trouble_codes/gm/gm-2-digit-codes.php
66- pressure sensor or circuit air conditioning
http://www.cadillacfaq.com/faq/answers/dtccode.html
DTC 66 - Driver Air Bag Deployment Commanded
Apr 09, 2016 | Cars & Trucks
Gfe28 fridge with a sa 66 code when plugged in
GE refrigerators and a lot of new appliances have a mode called sabbath mode or SA 66. it turns off your lights and advanced features for the weekend. To exit sabbath mode push and hold light and lock for 3 seconds, or for some models it's light and alarm for 3 seconds.
Jun 30, 2015 | GE Refrigerators
What is Error code 66?
Error code '66' is a rare case. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Error codes, and LED blinking codes to many popular brand remote controls are given.
May 06, 2014 | Mitsubishi WD-Y657 65" HDTV
Eror code 66 how to fix it
you might want to unplug the set and plug it back, my list does not show a code or error code 66 for this set. Power it up and let it fail and check for the error, if the wrong model was posted here that may be the reason.
Dec 23, 2012 | Mitsubishi WD60735
Mitsubishi wd60735 error code 66
No such error code that I can find, try to unplug and let it fail again, then do the check again.
Dec 23, 2012 | Mitsubishi WD-60735 Projection Television
What does an error code 66 mean on a noritz Model N-0751M
http://www.noritz.com/u/pages_from_field_manual_2010_12_09_pdf__adobe_acrobat_professional.pdf
The Noritz field manual says that error code 66 is Bypass Water Control Valve failure. Call support at 866-766-7489 with your model #, serial # (both on the unit face plate), date of purchase, to see if the valve can be replaced under warranty.
Jul 14, 2012 | Water Heaters
Machine says "I need service"
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
I took this from the service repair manual. Hope it helps.
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66. On some machines the pressure switch is seperated and sometimes the plastic tub for the switch gets clogged up and blowing through it will sometims clear this fault. Not sure about this particular machine, but you can try adjusting water level to see if it will work at a different level of water.
Mar 24, 2011 | Fisher and Paykel (IWL12)
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
Kitchen Ranges Logo
90 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
