Question about Motorola Mobility RAZR V3
PIN is incorrect
I just bought a bluetooth for my RAZR but it wont connect. If I try to connect it to a different phone it works...but when I try to connect to my phone it keeps saying the PIN is invalid. The pin works on every other phone but mine.
I tried the master reset..tried turning the phone off and on..the bluetooth off and on.....but it still says invalid pin. I know its not the bluetooth itself b/c it will pair with other phones but not with mine
Posted on Jun 29, 2008
    Brigadier General:
  • 7,752 Answers
Well unpair then master reset the phone and try pairing it again.
Bluetooth not powering up
Try this ::
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life. 2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is sually provided by the Bluetooth device manufacturer, not the RAZR. Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
PLEASE DONT FORGET TO RATE THIS RESOLUTION.
Nov 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Pairing my Motorola Razr with my Motorola H12 Bluetooth Headset
-put the headset2.gif in the covered charger (not plugged in)
-hold down all 3 buttons for at least 10 sec
-leave headset in charger (unplugged) and enter in 0000 when prompted for pin.
Sep 04, 2008 | Motorola Mobility RAZR V3
Connecting to my bluetooth
maybe it is not compatible with that model headset...but you should take it to a mobile shop and have them try to connect it for you.
Aug 22, 2008 | Motorola Mobility RAZR V3
Bluetooth connectivity problems
master reset your phone....then try again.
May 27, 2008 | Motorola Mobility RAZR V3
Don't know the pin to set up my bluetooth
Most Motorola bluetooths have a default passcode of 0000 and cannot be changed.
Mar 14, 2008 | Motorola Mobility RAZR V3
Bluetooth pass key invalid only on my razr, not on other phones
try master resetting the phone, see if that helps.......if not take the phone and ahve them reflash the phone's firmware.
Feb 25, 2008 | Motorola Mobility RAZR V3
Bluetooth message is "unable to connect"
has the two phones been syncronized if so what file format are they in as most wont work on newer phones
Jan 05, 2008 | Motorola Mobility RAZR V3c Cellular Phone
I can't get my phone to connect with other peoples
I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
Dec 14, 2007 | Motorola Mobility RAZR V3
Can't connect with other peoples phone
Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Motorola Mobility RAZR V3 Logo
139 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
