Question about Elna 2007 Mechanical Sewing Machine
The material gathers when i sew - Elna 2007 Mechanical Sewing Machine
  • 323 Answers
Rethread the machine from the spool to the needle.All machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.
You need to be sure your tension is working correctly. Adjust the tension to 9 and pull the thread. It should be hard to pull. adjust the tension to 2 and it should pull much easier. If it works as described, then adjust the tension to 4 and your stitch length to 2.5 and try it on some medium weight fabric.
If you are sewing on light weight fabric set your stitch length to 1.5 or 2. You may even have to reduce the tension to less than 4. You can reduce the tension until you see loops on the bottom of the fabric at which point you should tighten the tension to remove the loops.
sewman7
Posted on Jun 29, 2008
Doing simple stitch, but the result is gathering fabric?
If you are sewing by hand then you are pulling the stitches too tight and it causes the material to gather. To prevent this lock the length of your stitch by going back over the last stitch and through the previous stitch or if near the edge. Do a blanket stitch. Using a machine simply alter your stitch tensioner
Jan 14, 2018 | Sewing Machines
Can I watch a video on how to fix a singer sewing machines that gathers fabric?
Most common faults for material gathering is either tension too tight for thin fabric or there may be a slight burr on the needle
Sep 30, 2013 | Sewing Machines
Why do my feed dogs grap my material at the beginning of a stitch
some sewing machines have what is called a buttonhole lever that
is to the left of the needle that has to be pulled down before the
machine will make a buttonhole,here is a link for a free manual
if you dont' have one
http://www.singerco.com/uploads/download/430_8280_es.pdf
Mar 18, 2013 | Singer 8280 Mechanical Sewing Machine
There doesn't seem to be a stitch long enough on machine for basteing so I can gather material?
Try loosening both top and bottom tension. while longer stitches are easier, it can be done on shorter stitches as well. A bennifit to shorter stitches is the gathers will be smaller and easier to work with! Remember to reset the bobbin tension before sewing again.
Dec 16, 2012 | Janome 8080 Computerized Sewing Machine
New home machine model 677
What do you mean by "rucked up?" You'll need to be more specific. Does the machine gather or pucker the material?
Nov 25, 2012 | New Home Sewing Machines
My top thread is making a mess when I try to sew. It bunches up and gathers the material into a mess. Please help
I believe your tension is to tight. Loosen your tension dial, while using a piece of scrap material. Continue till you achieve tension you are happy with. GOOD LUCK.
Jul 05, 2011 | Singer 2732 Mechanical Sewing Machine
Drawing matereal under footplat at start of sewing and tryes to gather slightle when sewing two thiknesses together ,sewing sattern to linning
Suggest checking proper bobbin tension, and you may need to add a evenfeed foot so the top and bottom material feet at the exact same speed and length.
Feb 08, 2011 | Singer 7442 Mechanical Sewing Machine
I have a Pfaff Hobbymatic 927, while I am sewing, when the needle goes down into material, sticks abit and gathers the material a little and then on bottom side of material threads of material show a...
Try changing to a new needle preferably size 80 universal. If you hear a little popping sound when you sew, that's telling you that the needle is bad and is no longer sharp. The needle either has no sharp point or has a bur on it which is pushing down into the material making a hole and on the way back out it's pulling the fabric with it. Let me know if this works for you. Good luck.
Sep 10, 2010 | PfaFF Sewing Machines
Gathering foot Not Gathering.
check the amount of pressure on foot, it might be too much for the type of material, that sometimes makes it gather
Jan 20, 2008 | Brother 1034D Mechanical Sewing Machine
Elna 2007 Mechanical Sewing Machine Logo
169 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
