Question about Samsung LN-S3251D 32 in. LCD HDTV
BLACK BOX I am technically challenged, so how do I get rid of the black box exactly step by step. I have tried finding close caption on my menu, but cannot locate it - help - the black box is driving me into a black hole!!! Thanks,
  • rosssie Nov 28, 2008
    Did you ever work out a solution to this issue ? We have the same problem. We can't get to the cc from the set up menu because the TV keeps scrolling through the menu.
If when going into menu, the menu just keeps scrolling automatically then there is a circuit board fault within one of the electronic components. The only solution is to request a Samsung service technician. Cost of repair for us was $392.00. The technician said that this was a common fault with this televison !!!
Posted on Dec 12, 2008
My t.v. started doing this EXACT thing this afternoon. The "Not Available in Current Mode" message will not go off. When I go into the menu, it scrolls automatically very fast. I am not able to click anything. I wonder what is going on.
Posted on Aug 02, 2008
Ok, with a samsung go into your menu then down to the setup tab and you should see the caption sub menu under there.
also a samsung it is on your remote that came with the tv or should have, Hope this helps.
Posted on Jul 28, 2008
We get a black square on Fox and one children's cartoon network only. I have close captioning set off on my Uverse box menu. Is their anything else I need to do on the Olevia setup menu to eliminate the...
This is most commonly caused by the use of a Closed Caption text box. This type of Closed Caption is not always supported by the broadcaster, and results in the appearance of a black rectangle with scrambled or no text.
This can be quickly resolved by adjusting the Closed Caption type to "CC1" or by disabling the Closed Caption feature on your television.
get in the menu and change the close caption with the Olevia remote control
This should fix you right up
Dec 03, 2010 | Televison & Video
My son played around with the menu button and now we have a big black rectangle in the middle and don't know how to get rid of it.
Simple solution that black box is the closed caption, you can find in menu, or on remote. Switch closed caption off.
Nov 06, 2010 | Sony Televison & Video
When I turn on the TV I see a very large black box and tv is ok behind How do I get rid of Black box area?
This sounds like one of closed caption features, there will be a CC button or menu option to adjust Closed
Captioning - you will need to select the "off" choice and it should remove the box. Once my TV had a similar problem...activated by my cat stepping on the remote.
Dec 05, 2009 | Cars & Trucks
TV has a black square box blocking out the channel
this is probably the closed captioning option, go into the menu and turn off closed captioning, its probably on text....Hopefully this helps
Jul 18, 2009 | JVC RM-C745 Remote Control
Black box when tv is on and going through channels
This worked on my tv...give it a try:
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | JVC AV-36S33 36" TV
Black box
Go to your menu and turn off the closed caption
Nov 07, 2008 | Olevia LT42HVi 42 in. LCD Television
Black box pops up on tv
You have activated the closed caption.Go in to your menu and set the closed caption to off.
May 12, 2008 | Televison & Video
Closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
Nov 14, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
DAE WOO BLACK BOX
It is the TEXT mode of the closed captioning system, just go to the closed caption in the menu and change to off.
Apr 27, 2007 | Daewoo DTQ-20U4SC 20" TV
Samsung LN-S3251D 32 in. LCD HDTV Logo
93 people viewed this question
Jerry Greenberg
Jerry Greenberg
