Question about Admiral AAV7000A
Have an Admiral AAV8000 that does not stop
My washer keeps going through the cycles without stopoping. It finishes a cycle then starts filling up again. It has to be stopped manually.
Harold
    Novelist:
    Champion:
  • 261 Answers
Sounds like you have a mechanical failure and the timer keeps advancing because the cam contact for the timer motor has to be manually shut down. Your timer is part 21001929
Posted on Oct 04, 2008
My admiral washer does not work on wash cycle. It will rinse and spin on any cycle but wash
hi Marilyn.
this is what i have found but not sure if this will help you out,if not go to the link at the bottom and see if it helps you out.
Step 1
Make sure the washer's cord is plugged in to a functioning outlet if the Admiral washer won't fill with water. Check your circuit breaker to make sure the power is on and reset it if necessary. Reset the dial and start the washer again. Turn both of the washer's faucets on to full power. Untangle any inlet hoses to remove clogs. If this doesn't work, your hose filter screens could be clogged. Disconnect the hoses from the washer and clean the screens of any residue.
Step 2
Close the washer's lid completely if the Admiral washer will not agitate. The washer will not start if the lid is open. Restart the washer by setting the control dial to the desired cycle. Momentary pauses during cycles can be expected. You may need to wait a minute or two to see if the washer starts. Check the circuit breaker to make sure the washer is getting power. Reset the circuit breaker if necessary.
Step 3
Check and reset the circuit breaker as above if the Admiral washer will not spin or drain. Untangle any of the washer's hoses to allow water into the machine. Check your drains for clogs that may be preventing water to move into the washing machine. Close the lid and restart the washer. The washer will not start if the lid is not completely closed. If there are excessive soap bubbles in the washer, the washer may have locked up because of this. Wash the load again without adding detergent.
Step 4
Rearrange the laundry so it is evenly distributed if the Admiral washer stops or if laundry is still wet at the end of a cycle. Untangle any laundry from the center post in the wash tub. Select the correct water level for the amount of laundry. Select a normal spin cycle for jeans, towels or other heavy loads. Close the lid and start the washer.
Step 5
Check the hoses to make sure they are tightly connected to the Admiral washer if it leaks water. If they are loose, tighten them with a screwdriver. Make sure the drain hose is secured to the drainage area. Avoid putting too much laundry in your machine or soaking laundry for over 30 minutes.
Step 6
Make sure the Admiral washer is on a level plane if it is excessively noisy. If it is not on even ground, move the washer so that it is level. Remember that some washer noise is normal. Thin floors can cause the washer to vibrate and move about and the noise level may rise and fall depending on the speed of the cycle.
admiral washer does not work on wash cycle Google Search
Nov 25, 2017 | Washing Machines
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
My admiral washer will not fill up with water nor will it wash
Hello Melyssa
Have you tried both hot & cold water?
different settings?
stop mid cycle?
need more info
Jun 10, 2015 | Admiral Washing Machines
Admiral LNC6762B water keeps running when starting
try these one of the following is not operating properly.
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Oct 19, 2009 | Admiral AAV7000A
Washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Feb 20, 2009 | Admiral AW22 Top Load Washer
Admiral AAV7000A Logo
110 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
