Hitachi CP-S235 Multimedia Projector Logo
Anonymous Posted on Dec 08, 2010
After replacing bulb which was nearing end of life there is an overall yellow tinge to the projected image.
2 Related Answers
Anonymous
  • 336 Answers
  • Posted on Nov 03, 2009
SOURCE: Picture issue
Hi,it sounds like the LCD chips that create the image and colors.These chips are green,blue and red.These chips are like tiny screens that blend together to create the image and colors.Over time the LCD chips start to melt and those spots will appear.Unfortunately they dont sell the chips by themselves so you will need to replace the light engine which cost sometimes as much as a new tv.Good luck and God bless you!
Anonymous
  • 16 Answers
  • Posted on Mar 17, 2010
SOURCE: Hitachi projector model CP X260 projects yellow spot on screen
blue blotches on screen due to dust get optics cleaned should then work ok...yellow spot more likely to be lcd or lens burn a much more serious and expensive problem
1helpful
On the front of my 50 inch tv the yellow bulb light flashes.i pulled the bulb and it seems ok
It's probably telling you that your bulb is nearing the end of its life. (At least it's doing its job -- half the time these things give you no warning at all.) So buy a replacement bulb for the day when the old one dies. You can turn off the annoying light by going into your set's menu and telling it you've just replaced the bulb. Be sure to do that again when the bulb actually dies and you replace it, so it doesn't give you a very early warning next time.
My epson projector shows a non growing yellow tinge in the centre of the image. The projector is about 4 years old. EMP-TW700. I am a fairly heavy user.
From my experience, the projector bulb has most likely received a blemish of some kind from something such as accumulated dust on the front, to a fingerprint from where it has been handled by someone replacing it.
This yellow tinge then occurs when the blemish is burned onto the surface of the bulb.
In my opinion, unfortunately, you may need to get a new bulb.
Hope this helps!
1helpful
What does it mean by projection lamp is nearing end of life? how can i fix this?
Ur tv have bulb,it a lamp that project the picture.It have life spans about 1400 hundred hours.It come close to the time near the end.Change another lamp when the front LED lamp indicator flashes.
IXD 420U projector takes a long time to project and has pink ima
If possible, try to replace the VGA cable between the projector and the computer. A bent or broken pin, or a damaged wire, can prevent the blue or green (or both) portions of the picture from being displayed. The result is a reddish/pinkish picture.
As for the long time to project an image, this could be an extended warm-up time. How old is the bulb in the projector? Does the projector have an option to display the hours used and/or remaining on the bulb? Bulbs do have a finite life, and when they near the end of their service life, they can become more difficult to start.
Hope this helps!
Bulb working but screen yellow orange tint
Many projector bulbs will go yellow when they near the end of their life, is it an old bulb?
Samsung hc-p4252w - yellow tinge on left side of screen
If you put magnet speaker ( Standard speaker) near the TV, first you must move that speaker away from your TV because this will cause your colour TV screen color scattered. Then switch off your TV for 5 hrs. then switch it ON again your problem will be solved if the degaussing coil working.
I just purchased a bulb for my LG TV model: RU-44SZ63D. I put it in and the yellow light is on that signals the bulb is nearing the end of its service life. Can this be possible? I paid $110.00 for the...
I'm sure that many lamps in these models get replaced unnecessarily. The problem is the contacts where the lamp assembly plugs in. Remove and replug the lamp.. Mine has aluminium foil jammed in the connectors for 2 years now and hasn't failed since.. Prior to doing that I had EXACTLY what you described. No more LG for me
2answers
Color problem with Toshiba
tv is on it's 'hospice' end of life routine..unless you want to gut it completely, and replace all the electronics..
Projection tv lamps
All fillament based lights will dim as they age. Some of the newer/better types it will be unnoticible.  If you are losing image quality or brightness you may have a bulb that is nearing the end of it's life cycle.  A glance at you owners manual or the manufactor's website should give you an indication of the expected life of your bulb.  Also most of the projector made in the past few years have a counter that tallies the amount of hours your bulb has been on.  A more likely culprit is probably dust accumilation somewhere inside your projector. Most projectors have filters these days and need to cleaned at certain intervals and in certains ways.  Not cleaning these filters can cause heat build up that can increase operating temps and shorten the life of your bulb and or projector.  Or sometimes jsut fail and cause a dramatic decrease in image quality.  Again these things are vendor/model specific so you will want to check with them about your particular model. Hope this helps.
Top Hitachi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
