Question about Electrograph Systems DTS50PTD 50 in. Plasma Television
Picture The 50 plasma Model DTS50PTD has no picture at all. The power light turns green when powered up and I can hear the relay trip. Can't see anything on the screen. What do I replace to fix it? Lamp? Circuit board? ECT!!!. Thanks survaccessmcneil@hotmail.com
  • survaccess Jun 28, 2008
    Good Job. Survaccess. Electronics Technology Puget Sound Community College Olympia Wa.
    Genius:
  • Electrograph... Master
  • 1,689 Answers
There are no lamps in a Plasma display. The fault can be anything from the power supply to the drive processor. On some occasions I have seen the display itself go defective.
I would not suggest buying boards to service the set yourself. You can end up guessing at boards that are not defective, and when installing a new board it blows again, because there are other faults that were the cause of the failure in the first place.
The service rep will test the set using factory diagnistics and board substitution. When he finds the defective boards, he will install and adjust the new boards as necessary. I found that when the power supply is defective, there are usualy other faults in these sets.
If your set is out of warranty, you may find it very expensive to have it serviced.
Jerry G.
Posted on Jun 28, 2008
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
My Philips plasma only shows half the screen. The other half is just blacked out.
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
Sep 14, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Hitachi 50" Plasma (P50X01AU), power light comes on but no screen
Hope you already resolve it, if not, here what I went through 1. Try to get a service manual for your model ($10-18) from http://www.service-docs2.com or similar place. 2. Open the back and follow instructions how to remove and test the SDR-D and SDR-U board on the far left (take one off, see if you could see half the picture). Inpsect the chips on those two boards, you might be able to spot the burned out holes (that would be the defected board, seemed to be a known issue for particular models) 3. If it is the board, go to ebay and get the pulled out board replacement ($70-90) I fixed my 50 inch plasma this way
Apr 26, 2009 | Hitachi 42HDT79 42 in. Plasma Television
NO PICTURE, NO SOUND On My Plasma TV.
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
gysgt2u1@yahoo
Mar 05, 2009 | Philips 50MF231D 50 in. Plasma Television
No picture or sound
The Plasma panel could be bad or the power supply may have went out. What is the model # and what is the date of MFG?
Let me know that info and i can be of more assistance to you. Thankyou in advance. Jay
Jan 31, 2008 | Zenith D52WLCD Television
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Electrograph Systems DTS50PTD 50 in. Plasma Television Logo
91 people viewed this question
Top Electrograph Systems Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Henry  Thomas
Henry Thomas
Are you an Electrograph Systems Televison and Video Expert? Answer questions, earn points and help others
