Question about Panasonic NV-GS4B Mini DV Digital Camcorder
Failure to initialize DV capture
Irish druid,
I am running Windows XP.
Does your advice still apply?
  • pratchett Jul 05, 2008
    I think we have exhausted almost all possible solutions now.
    One final thought.
    My USB Operating Instructions states that after making connections and turning the equipment on,the Appropriate Driver to recognise the Movie Camera is automatically installed by Windows plug'n play when connected first time.
    If this does'nt happen how do I get Windows to install?
  • 2,712 Answers
Sorry..but I dont have the link to previous query, if you can provide me that, I can go over it again. Sorry, but I get swamped with queries, and its difficult to remember the details of every query I get.
I do apologize for this..Kindly post the link here, and I will be happy to assist you..
Posted on Jul 01, 2008
Windows 7 64 bit driver for Panasonic NV-GS25GC camcorder
XP SP3 is 32-bit. Unfortunately, not all of the drivers that were available on the 32-bit Windows have been moved to the 64-bit versions.
Aug 07, 2014 | Panasonic Video Cameras
I can't initialize on FCP
If you are capturing HD, go into the menu > IN/OUT REC > i.LINK CONV and set it to off, and A/V->DV OUT to off. Go into FCP and go to the File Menu and select "easy setup". In the easy setup menu set the "Format" to "HDV" and set "Use" to HDV - 1080i60. Click "Setup". Now go to File > Log and Capture (command-8). You're now set to capture. Just queue your tape and hit "Capture Now" or set in and out points and capture "Clip".
If you want to capture SD footage, then on your Sony unit, go to the menu and set the i.LINK CONV to "on". In the easy setup menu you will want to set "Format" to "NTSC" and "Use" to DV-NTSC".
Sep 26, 2008 | Sony GV-HD700 HDV VCR
Hi there cannot connect i link to my pc no connection on my pc any advice would help
Usually what you would do is buy a IEEE-1394 interface card and install it in your PC in an available slot on the motherboard. You can buy these for less than $20 and with a little tech knowledge about PCs many people can install the card themselves. The IEEE-1394 is called i.Link by Sony. If you are running Windows XP, or Vista, the drivers are already installed. Reboot PC and the new card should be recognized. Use the 4-pin to 4-pin firewire cable to connect camcorder to PC. You will need software to capture your video which should have been supplied by Sony with your camera. For Windows 7, you need to install LIVE Photo Gallery. Your camcorder was setup to work with Windows XP so an alternative may be to just find a friend with an older PC with a firewire card already installed running Windows XP. I just did this very same thing on my PC and it worked. Got the firewire card from for $3.95 VIA brand from Taiwan. I used Windows Movie Maker to capture video. Sony also sells a stand-alone DVD recorder which connects to a camcorder and requires no computer to create DVDs of your video.
Mar 18, 2011 | Sony Handycam DCR-HC24E Mini DV Digital...
Error 5100 on PIXMA MP470
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 19, 2009 | Canon PIXMA MP470 All-in-One Printer
New vista lap top....using my VIDEO STUDIO 8 program
no, this is not, u need to learn the application by user manual or any other help, otherwise use some other application like adobe primeir etc.
Nov 17, 2008 | Ulead Videostudio 8 for PC
Problem in video capturing through firewire
Hi Sreeki,
You may have solved this problem already but I had the same problem some time ago, so the advice will be a little vague.
From memory the issue is something to do with corruption of a directx file so you could just try re-loading directx.
But the way I found a solution was to try and capture video using windows movie maker and you will find the video capture also fails using this software. However, windows returns an error message (which I cannot remember), and I did a search on Google or something for this error message and eventually found the solution.
It was related to directx and there was a small file that had to be run to repair it.
Hope this helps and I will continue searching for the problem I am now having with my camera not accepting a tape and returning the error message relating moisture......
Mar 29, 2008 | Sony Dvcam DCR-HC15E Mini DV Digital...
Capturing DV
same thing for me any help ?
Jan 08, 2008 | Panasonic NV-GS230 Mini DV Digital...
"A video capture device was not detected"
It is unlikely that the 'latest' drivers will work with an unsupported OS like XP
Nov 05, 2017 | Sony Handycam DCR-TRV19 Mini DV Digital...
Unable to tansfer video to computer using DV cable..
Pinnacle software will recognize the camera installed through a firewire cable once the camera is turned on. Windows movies software doesn't recognize DV cameras. You may be able to get capture to work if you go to and download the Windows Media 9.0 Development Kit. I believe DV input is a capture option.
There has to be a 3rd party program installed to get it to recognize it.
Good luck on that.
Sep 20, 2007 | Canon ZR800 Mini DV Digital Camcorder
Windows 98'
We confirmed the following software and drivers compatibility with Windows 95, 98, and ME. Picture Navigator JLIP Video Capture JLIP Video Producer JLIP Video Player Card Navigator USB Drivers GV-PT2 Printer driver & Capture GV-DT1 Printer driver & Capture Video Navigator None of the above software will be compatible with Windows NT. At this time there are no drivers available to make these software programs compatible with Windows NT. There is an update available for the Picture Navigator software to work with Windows 2000 and XP in the Customer Support area of this site. (When executing the update be sure to have Picture Navigator closed). The following versions of software and drivers will work with Windows XP. Picture Navigator JLIP Video Capture 3.1 JLIP Video Producer 2.0 JLIP Video Player 1.0 Card Navigator 1.0 USB Drivers Video Navigator
Sep 14, 2005 | JVC GR-D70EK Mini DV Digital Camcorder
Panasonic NV-GS4B Mini DV Digital Camcorder Logo
69 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
