Canon PIXMA MP210 InkJet Printer Logo
Posted on Dec 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change cartridge - Canon PIXMA MP210 InkJet Printer
Anonymous
Level 3:
  • Master 641 Answers
  • Posted on Dec 08, 2010
Anonymous
Master
Level 3:
Answers
641
Questions
5
Helped
152840
Points
1511
Get the manual from this page. http://www.retrevo.com/s/Canon-MP210-Multifunction-Printers-review-manual/id/3124ci175/t/1-2/
How to change the ink of printer Epson stylus Office BX300F. Show me in the computer to change the ink in printer now.
Turn on your printer and raise the lid or press the cartridge changing button. Wait for the cartridge carrier to slide out.
Lift the cartridge holder lid, and the cartridge will pop up for removal.
Carefully remove the tape from the ink opening on the bottom of new cartridge.
Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
Close the cartridge holder lid and press the cleaning button to charge the cartridge.
Close printer cover.
Watch here full details:-https://www.youtube.com/watch?v=8gL5xoiDenA
Still unable to change the ink, you should go to customer support at +1-800-243-0051 ' +1-800-243-0019
Change ink cartridge epson NX230
Change Ink Cartridge in Epson Printer isn't a difficult. Just follow the simple steps to change ink cartridge in Epson Printer:
·Turn on Epson printer·Open its cover or scanner then left the unit of the scanner and wait for it.
·Ensure that the print head is at replacement position. If not the press "Maintenance" button.
Follow the more steps to change ink cartridge in Epson Printer.
What is the cause of my printer o be saying change cartrige when i already change it
It may be some reasons:
1. Cartridge incorrectly changed. Just be sure to remove and set the new cartridge correctly.
2. No good connection. Sometimes ink spills on the cartridge connectors OR the protective plastic still set on the cartridge. Clean the connectors with a soft cloth and be sure to remove the plastics - see installation guide on cartridge.
3. No procedure was done. To change a cartridge correctly, some printers require a procedure for it, be sure to read the user manual how to change cartridge.
Other non-common issues: bad new cartridge, faulty printer, software or firmware glitch, etc,
1helpful
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Cannot use ink cartridge after initialization. Happens every time I change cartridges although cartridge was sent to me by HP themselves. When do I change the cartridge - I presume before I turn the...
You change the cartridge whenever the printer software says to, or when the color starts to fade on prints. You can change the cartridge with the computer and/or printer on or off, it doesnt matter
NX400 printer - cartridge not positioned to change cartridge
The problem occurs when trying to change a low ink cartridge before you are prompted to do so. In that event, you must go to setup, maintenace, change cartridge and it will move the cartridge into position.Do not try to force the cartridge into position.
How to change printhead in hp7210 aio
just change the cartridge the head comes along with the new cartridge in HP everythime u change cartridge the pint head is changed automatically as it is fitted on cartridge,
if u are having lines and streaks and noisy prints just change the cartridge with a new one branded HP from HP website u can buy supplies
pls rate me FIXYA for help
1helpful
Changing ink cartridge
HP 1610, Remove Cartridge message
also replace the colour cartridge as it is not showing but the printer is not able to detect that cartridge also.many a times it solves the problem.
old marine
old marine
ZJ Limited
ZJ Limited
