Question about HP LaserJet 1300 Printer
HP LaserJet 1300 Printer - Won't feed paper
HP LaserJet 1300 Printer will not pick up the paper on which to print. I can hear clicking like it is trying to work, but doesn't.
Any ideas?
  • 61 Answers
Firistly try to find out the printer is ready or not then find out when we powearing on the printer then it is warming up or not if it is warning up and not come to ready position then open front cover pull the toner cartage and send back it propely
then give print if the problem is not solved then ckeck the printer cables and drivers
Posted on Jun 28, 2008
LESERJET 1300 NOT PICKING PAPER
Not picking up paper is usually caused by feed and pick up rollers worn out and has slick spots on then. Replace the rollers
Jan 26, 2014 | HP LaserJet 1300 Printer
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
My HP laserJet 2200DN doesnt feed paper when printing.
it could be hardwre problem.. you need printer technician to replace some broken parts
Aug 25, 2009 | HP LaserJet 2200dn Printer
Printer printed paper with crushing sounds, but
You need to continually press the paper feed button (next to power) while applying gentle pulling pressure to manually feed the paper all the way through the printer. Hope this helped
May 09, 2009 | HP LaserJet 1300 Printer
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
I am getting verticle black streaks when I print, please help.
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Nov 21, 2008 | HP LaserJet 1300 Printer
HP Laserjet 1300 will not feed paper
You may need a new roller, or pad.
Aug 11, 2008 | HP LaserJet 1300 Printer
HP Laserjet printer not printing
Try clearing the que. It may be the first job is to big for the memory. Also, be sure the printer is not in manual feed mode. The directions will be in the user manual if you are not sure how to change it.
Jan 19, 2008 | HP LaserJet 1300 Printer
Paper feed
Yep the paper feed roller wears and will need replacement (open front cover in centre of machine tabs on either side it just clicks out.
should also change sep pad (multi feeds)
Here in LINK to purchase items pic below
Dec 21, 2007 | HP LaserJet 1000 Printer
HP LaserJet 1300 Printer Logo
372 people viewed this question
Ben Johnson
