Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
My disk got formated, so i can launch u3!
Someone formatted my 4GB flash,as a result i can't launch u3!
  • 284 Answers
There are some recovery program for flash drive.
you can google " recover flash drive
you might get a few things
Posted on Aug 04, 2008
I have a sandisk disk on key with a 4gb memory capacity. it currently has NOTHING stored on it yet says i only have 1.45 gb free. how do i clear this up? is there a way i need to format...
Hey gita! Formatting a Flash drive is really simple! Assuming you're using Windows, plug it in your PC and go to My Computer. Right click on the drive and press Format. You can choose either Quick format or normal format(Quick format does it really quickly but it may not yield best results). After that simply press Format and wait for it to finish.
You should have formatted your Flash drive and have your original 4GB of space restored!
Keep in mind that you may have less than 4GB(about 3.8-3.7) This is because formatting writes instructions to the flash drive.
Have fun :)
Aug 21, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My sandisk cruzer 4 GB pendrive ws working fine but now whenever i try to format\copy\cut it shows location 0 with used space 0 free space 0 what should i do
Your flashdrive usually shows 2 drives when inserted to your computer, one is the U3 drive and the other one is the removable disk drives. U3 drive is your separate partition for the U3 system and in order for you to store, copy, format your flashdrive, you should be selecting the removable disk drive, not the U3 drive. U3 is a read only memory drive that is responsible for your U3 to work (just like portable applications). Hope this helps.
Jul 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a 32GB sandisk cruzer stick. I've used what is called diskpart in Windows 7 to select and format the stick in fat32. I'll take it to a Windows XP box and try to drop a substantial size file to...
Sorry but you wont be able to put a file larger than 4gb due to file format limitation since you used fat32. only NTFS supports files larger than 4gb. if you want to use it with large files you need to format again using NTFS. hope that helps!
Mar 23, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Launchpad installer
If you are using Windows and have not formatted the drive or otherwise tampered with it.
Open the Windows explorer.
Plug the device in a USB port and wait for the computer to recognize it. After it is recognized the Windows Explorer will show two additional icons, one of them a CD-ROM.
Click the icon with the CD-ROM, and it will execute the U3 operating system. A small yellow icon with a U3 label will appear on the task bar. Right-click the icon on task bar and select the "Open U3 Launchpad". Point to the Settings button on the right side.
Right click that button and select the U3 LaunchPad settings
In the window that pop up point to "Autorun" button and click it.
Click the button that will say Enable.
After that it will launch automatically whenever the device is recognized by a computer.
If the U3 launchPad is missing from the device you can download it from the SanDisk site. Here is the link. Download it and install it on your computer. Note:It does not launch on MacProducts or Linux.
Aug 19, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
When adding files to scandisk 4gb u3 usb it says that the disk drive is already full but the drive doesnt have any files on it.
The simplest method to solve a problem such as this is to reformat the drive. Open "My Computer" and "right-click" on the drive that is your USB drive and there should be an option in the context menu to "Format". Click on that, choose your formatting options and run it.
Jul 10, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Flash drive has a DVD ghost
It is "working as designed" for a 'U3' device.
A 'U3' device is _more_ than just an "ordinary" flash-drive.
You can install software onto a 'U3' device, i.e., a copy of Microsoft Office, and then you can take your data files _and_ your copy of the software _with_ you, and connect to any computer, and access your software and your files.
Jan 09, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk U3 Cruzer Micro 8Gb Cant Format :S
rite click on it in mycomputer and click propertys to see if your thunb drive even has memory on it could have ben fried by sum and has no memory now
Nov 07, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Had to erase USB drive Data, now Vmailer wants $40 for synch prog
Hi ,
you can try to get a free synch program for your U3 device , for example : Allway Sync n Go
if you want to delete the information on the device , you can format it as a regular Hard Disk (my computer, right click on the USB drive letter and choose format)
Jan 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Using U3 flash drive in photo kiosks
The drive should be usable after a full format. I have done this many times and I have yet to see a drive not work.
May 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
U3 launch pad error
Download Gparted disk partion tool, use the bootable ISO burn disk. Now boot PC with gparted and on the desktop is a icon for mounting usb drives, use this to mount the usb stick.Follow the instructions, when asked to install gparted on disk exit window by using "q+enter" key.
Now start the partion tool and mount usb drive and partion and format.
An alternative method is to use the partion tool found in most linux distributions such as in puppy or mepis.
Mar 19, 2008 | Electronics - Others
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
