Question about Kenmore Refrigerators
Kenmor side by side
Refrigerator is to warm
  • 1 more comment
  • ramarces1956 Jun 28, 2008
    small amount of ice buildup by the veg and meat
    buttom.
    no cold air circulating or caming out thru vents
    there cold air the comes thru vents ,is it
    coming from the freezer ?
    where is the defrost control timer located?
    by the way the freezer works normal.
    thanks for your help
    Master:
  • 638 Answers
Check whether the fan on the back is running perfectly if not try to replace it.that could lead this problem.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 28, 2008
    Genius:
  • 2,028 Answers
There should be a cleaning cycle setting on the temp knob, run the cycle. If not then unplug the unit over night, this will allow any ice build up that may have occurred and created a blockage, to melt. Then plug it back in and set the temp a little colder than normal to see if it's working properly. If you still have the same issue, then the problem is more than likely the compressor and you will need a service man.
    Genius:
  • 1,036 Answers
It could be the defrost control timer at fault. This controls when to defrost - and when the fan should come on.
Check this first.
  • Richard Perkins
    Richard Perkins Jun 28, 2008
    Try looking Here at part No. 3348
    If you need more info please contact again. Thank you.
  • 481 Answers
Possible causes:
dirty coils under the machine freezer side not defrosting door not sealing good weak compressor
  • Mike Durland
    Mike Durland Jun 28, 2008
    Sounds like a defrost problem. Check to see if
    there is any frost buildup in the back wall of the freezer. If so, it is not
    defrosting as it should.
    • possible causes:
    1. bad defrost timer
    2. bad defrost heater (in freezer)
    3. bad thermo switch in freezer
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
I have one and half year old Kenmore refrigerator. Model 106.58902802. Now suddenly refrigerator portion of it stopped working. All the ice cubes melted. Can you suggest what could be wrong?
Check compressor working. If yes,keep your arm on discharge side. It's warm and whistling sound (nicely) inside the freezer means it's working well.If no warm in discharge side, gas leak or chocked. Remove all gas, leak test and flush out the system. Then do gas charging.
Jan 24, 2011 | Kenmore Side by Side Refrigerator
My freezer is working great but my refrigerator is warm on my kenmore side by side refrigerator model # 59592992
Look for frost on the backside of the freezer. You might have a bad defrost heater. It could also be a bad evaporator fan motor.
May 06, 2010 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 57029 Side by Side Refrigerator
Kenmore 5458 refrigerator too warm. Freezer
It is probely freezing up. The cool comes from the freezer to the ref. side and when it does not defrost it builds up frost or ice and then the air can not get through. Could be a timer or a defrost heater.
Aug 04, 2009 | Kenmore Refrigerators
The door seal contact surface is hot to the touch.
ther so pose to be a switc if none that for hummit
Jan 17, 2009 | Kenmore 53082 / 53084 Side by Side...
KENMORE SIDE BY SIDE NOT COOLING
You should hear a fan running inside the freezer. It also blows cold air into the refrigerator side.
Jun 09, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore compressor cycles and does not cool
It sounds like you have a stuck compressor or bad start capacitor.
Stargazer
Mar 16, 2008 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
