Question about Microsoft Xbox 360 Console
Xbox does not work
Has one flahing light keeps saying system error e 65
  • tommy rocx
    tommy rocx May 11, 2010
    where does this error actually occur?
    When you first turn it on?
    The main menu?
    Scholar:
  • 45 Answers
Xbox does not work problem is one of the most common problem of Xbox 360. You will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Posted on Feb 21, 2009
Hi my name is kylie mccaskie and I have just brought an xbox off the internet about 2 weeks ago and when I got it home and turned it on the xbox came up with a system error but the dvd works on it but the games do not
Posted on Nov 06, 2008
Original xbox flahing orange light
You might have the so called "Lights of Dead" i had a related issue and sent it to videogame911.com they repaired mine, i had it back at the end of the week and they added a warranty.
Apr 21, 2013 | Microsoft Xbox Console
System error E68 comes onto the screan when we switch our xbox on. The box then flahes red on the power button on the xbox.
E68 is a system error that usually results from a hardware failure.
You can try removing the hard drive and applying the latest XBOX live update. If you have a slow connection, you can apply the update manually by going to this address http://www.xbox.com/en-US/Support/SystemUpdates
If this doesn't work, you will most likely have to send it in to Microsoft to be serviced.
Nov 06, 2011 | Microsoft Xbox 360 Console
My xbox is saying system error...?? how do i fix this or what does it mean
what else does it say there are a few different types of system error. if you could tell me what the lights around the power button are doing and what exactly your xbox says and when this happens i could try and help. sorry i would post this in the clarification area but it is not working at the moment for some reason.
hope this helps
Nov 27, 2010 | Video Game Consoles & Games
What is wrong with my xbox it says error 65?
Error 65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
Flashing red:
1.the av cable cannot be detected
Make sure that the AV cable is correctly connected to the Xbox 360 console.
Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
2.general hardware failure
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
Feb 08, 2010 | Microsoft Xbox Console
Red light blinking system error E74
this might be a hardware failure. try turning it off then back, or try keeping a fan on it when you play on and if that doesn't work call 1800myxbox there you'll find step by step instructions to send it down to texas and get it fixed. if that happens three times you will recieve a brand new xbox 360 that has that problem fixed. also keep in mind to keep your hard drive before you send it to be fixed. i really hope this helps with your problem
-good luck
Jul 14, 2009 | Microsoft Xbox 360 Console
2 left red lights blinking for one game
take yor game to gme crazy and get it buffed for 2 dollers
Mar 07, 2009 | Microsoft Xbox 360 Console
One Red Light in cpntroller number 4
Steve, what error code are you getting? Go here and find out what your error code means. http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Nov 23, 2008 | Microsoft Xbox 360 Console
Xbox 360 E 65 Error
I take it the drive is modded then?
Cheers
May 31, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
73 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
