FixYa.com
Tags:
GE 24 in. GSD2000Z Built-in Dishwasher
Can't get the dishwasher to start! (by 2 users)
posted by gjw25772 on Jun 28, 2008
When I turn the rotary dial to initiate a start, there is only a low hum. I rotate the dial all the way around and nothing happens. There is power and thereforem no blown fuse, as I can hear a hum. Not sure how to troubleshoot this! Any help greatly apprectiated! The GE dishwasher came new when the house was built in 1998. Not sure of the exact model, but it is in the range of GSD2000 --> GSD3230.
I appreciate any help you can provide!
Regards,
Grant
916.293-2950 cell
gjw25772@yahoo.com
Comment by gjw25772, posted on Jul 06, 2008
Thank you GEtech! Your solution worked perfectly! Just as you said, after turning the fan blade a few rotations, it broke free. I turned the circuit breaker back on and started the dishwasher. It immediately started the cycle as with water and continued through completion!
This website is extremely helpful! It saved alot of time and money!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 28, 2008
I had the same issue and problem. Washer would start with low hum. Water would add into basin. Washer would not drain. Removed bottom 4 screws and broke loose fan blades in back of motor. Works great now. Fixed in 5 minutes. Look like a hero to the wife.
Best Solution
posted on Jul 04, 2008
Helpful (85)
GEtech
Rank:Wiz Wiz
Rating: 89%, 15 votes
Sounds like the pump seal is stuck. Cut the power and look at the back of the motor. There will be a cooling fan in the end of the motor. take the fan and keep rotating it until the seals break loose.
Rating Locked! (?) gjw25772 has rated this solution as Helpful
Can you Help with these Dishwashers problems?
my model # is gsd5007 60ba
i cant get the latch to stay... Answer This...
GE Nautilus dishwasher won't...
one of our kids opened the door... Answer This...
Dishwashing Liquid Holder will...
I have a GSD2000J01ww... Answer This...
how to replace gasket on ge...
ge gsd2200g00ww ge Answer This...
no fill
starts, hums, timer seems okay,... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
