Question about Bosch 24 in. SHU53 Built-in Dishwasher
Replacing Control Module
I have a Bosch Dishwasher, Model SHU5312UC/U12.  We have been having problems with the wash cycle.  Specifically, when we turn in on with will start at 2 hour cycle, when the timer gets to 1 minute, it the wash continues until you stop it manually, or cancel the cycle by pushing the Cancel/Drain buttons.  From what I have read online, they recommend replacing the Control Module.  I ordered one and am about to replace the old one. I've taken off the door screws and the front door came off very easily.  But the top portion of the door that hides the control module will not come off.  Is there a trick to doing this?  Please help.  Thanks, Sergio
  • 2 more comments
  • PokerHer69 Jul 06, 2008
    Mike,
    Yes I did find the two screws on the sides.  Once I removed the screws, the top portion of the door came right out.  I did replace the module and the dishwasher is working great now.  Thanks for responding Mike.
    Sergio
  • Anonymous Sep 23, 2008
    I realize I need to replace the control module. How many screws do I need to remove on the door to access the control module? I am worried I may open the wrong screw and make the problem worse.
  • paintmagic Oct 15, 2008
    My Bosch shu568suc/u12 id running strange. won't stop
    I can fool it by setting the delay start.
    I am sure it is the control module but I cannot get the front pane off.
    I took out the screws but the top will not budge
    Please  let me know the trick
    thanks
  • kmorton Oct 29, 2008
    I have the same issue right now. Can anyone have a part number for the control module being referenced? Starts at 2h and runs continually while 1 is in the display and does not finish.
    Thanks
    Kevin
Sergio,
Did you get your problem resolved. By now I think you have found the two screws on the sides of the inter part of the door. Did replacing the module fix your problem. I have the same problem.
Mike
Posted on Jul 06, 2008
How do I fix the heater in my Bosch shu5306uc / u12?
SHU5306UC-12 BOSCH DISHWASHER Manual - Sears ...
www.searspartsdirect.com > Kitchen Appliance Parts > Bosch Parts
Download Manual for Model SHU5306UC-12 BOSCH DISHWASHER.Sears PartsDirect has parts, manuals & part diagrams for all types of repair projects.
Aug 01, 2015 | Bosch Dishwashers
How do I run a diagnostic test on the Bosch shu5315uc/u12? The cycle time of my dishwasher is at least 4-5 hours.
Long running time on a Bosch dishwasher is almost always a blown solder joint at the heater relay on the control board. You can resolder the joint, replace the relay or replace the control. Control board part number is 00266746.
Jan 13, 2015 | Bosch Dishwashers
I have a Bosch SHU4322uc/u12 dishwasher remove wires from control module, should have taken picture, but did not,need to know where to plug wire into control module thx
Look at the notches in the control and on the wire connections. They are all different and only fit in their own spot.
Dec 30, 2012 | Bosch Dishwashers
Bosch shu5316uc filling fault
Test the water inlet electro valves.
May 26, 2017 | Bosch SHU5316UC Dishwasher
Bosch Model shu9925uc/u12 not draining throughout cycle. Dirty, soapy water left in bottom of dishwasher at end of cycle. Help!
ensure filter in bottom of machine is not blocked. if clear
suspect blocked pipe or defective evacuation pump.
i hope this was helpful
Dec 12, 2010 | Bosch SHU9925UC Built-in Dishwasher
I need to look at bosch SHU5312UC exploded viewe of the door
I think I know the pieces you are referring to and you can only install them one way. I can direct you to searspartsdirect.com and if you enter your model number you should have access to several breakdown illustrations of your d/w however, I`m here to tell you, don`t sweat it. Most illustration`s I`ve seen don`t even show them either.
Those two blocks ( which slide into the front of the hinge behind the door panel by the way ) can remain left out without any functional consequence to your dishwasher. In fact the regional training representative for north america used to joke with us techs how he had a collection of them from tossing them into his toolbox instead of putting them back in place. They do increase the structural support of the front panel, but unless you plan on moving it around frequently, I wouldn`t worry about it.
If you are still concerned, post back with your email and I can send you a complete repair guide in "pdf" format for your dishwasher.
Hope this was helpful to you. Thank you for coming to "fixya" and please let me know if I/we can assist you further in this matter. Please take a moment and rate the info I provided for you here today.
Good luck.
macmarkus :)
Mar 30, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
My Bosch Dishwasher cycle runs for 2 plus hours!
If this unit is running for a long time it is because it is still try to heat the water temp up it is eather the control board or the heater.
Mar 28, 2009 | Bosch Dishwashers
Bosch SHU3322uc/u12
Hi Russellpaola
it sounds like to me that the water valve is sticking open. you should have it replaced
plz let me know if this helped
brent
Sep 08, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
520 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
