Question about Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT aquarius WF541G
I turn on my washer and after a few seconds it trips all the electric sockets in my kitchen any ideas???? The washer is 13 months old......typical!!! and has been fine up until now..... was turned off for a couple of months when we had building works, but has been in use for the last month fine.
    President:
  • 1,462 Answers
Most likely suspect is the heater. undo wires from heater and see if fault persists. if not, heater is down to earth and will have to be replaced.
another possibility is a leak causing some of the wiring to be wet
Posted on Jun 29, 2008
When i set my drier to dry on high heat it keeps tripping the electric with error code f-13 please could you advise me on why this is thanks
Indesit (Hotpoint, Ariston) 'F13's refer to 'thermistor circuit fault', 'dryer fan not working', 'dryer NTC (thermostat) fault' and other similar things! There CAN be problems with poor connectivity between cables and plugs/ sockets which could cause similar symptoms. It realy needs a service call to identify/cure, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 16, 2011 | Hotpoint Aquarius WD640 Front Load...
My hotpoint aquarius wdl540 keeps tripping the switch on the main fuse for the kitchen plug sockets
hello, the reason for this because theres a dead short inside washer or the socket may have a loose wire check all the earth wires inside the washer and the sockets get back to me if you still have trouble
regards
shaun
Jan 03, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint tcl 770 aquarius tripping electrics
REMOVE TOP OF WASHER AND CHECK WIRING ON FRONT RIGHT SIDE AS IT IS PRONE TO CHAFFING CAUSING AN INSTANT TRIP.
Jul 27, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
My washing machine it tripping the mains board out, changes plugs and sockets and its still doing it - any ideas? perhaps the bushes?
sounds like water is getting into the electrics....or your trip circuit has became week...try switching the trip switch from another circuit.
Jul 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi, i have a hotpoint WMA37s and half way thru a cycle it tripped my house fuse box. I changed the fuse and tried other sockets in the kitchen but it still trips the fusebox so i am assuming it is the...
It could be the heater, when you said halfway through a wash that would be about 20 minutes or so but the heater would have come on after about 10 minutes, but it is worth checking out (with a meter) or it could be a build up of carbon from the brushes, in which case a quick dust out of the motor housing will clear that. The other possiblity is a wire shorting out on the cabinet, this one is not so straight forward and will need some tracking down. If you have a Megger then do an insulation test for information on this use this link. http://www.selfix-uk.co.uk/Megger.html
Mar 03, 2010 | Hotpoint Aquarius WD640 Front Load...
All lights flashing on Hotpoint WF541G washing machine
It's probably a loose connection in the wiring in the machine. Seems to be a problem with the WF741 machines and is most likely a similar issue with yours. The probability is that the vibration from the machine is enough to work some connections loose. If you have someone competent to do this, then check that all connectors are pushed firmly onto their circuit boards. (I have posted a separate reply to this issue for the WF741 model on here.) See if this helps.
Oct 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
Sep 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Machine fills and drains at the same time.
Check the height of the drain hose and make sure the drain hose is higher than 30 inches from the ground. If your drain hose drains into the floor you may need to purchase a siphon break to stop the problem
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
174 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
