Question about Yamaha Audio Players & Recorders
I am trying to hook a turntable to RXV363 amplifier. The RXV363 does not have RCA jack inputs labeled for a turntable. I tried using the DVD and DVR Input. I think the problem is there is no an adequate ground.
  • 151 Answers
You need a phono pre amp to plug onto the phono leads of your turn table then into any input on the amp.A Turntable has a much lower output than cd or any other device so needs to be boosted,when you pluged it in I bet the sound was awfull.Buy the best phono stage you can .
hope this helps.
CABLE GUY.
Posted on Jun 29, 2008
Is it possible to connect a turntable to a technics HD51 amplifier ? There isnt a phono conection point
Are there any RCA audio input jacks maybe with the video labled "Aux"? If so, you can use only the Red and White jacks leaving the Yellow(Video) unconnected. Maybe you can attach a photo of the rear of this amplifier where the inputs are so we can show you another possibility...the mini computer input jack would be another choice with an adapter. Dave
Dec 23, 2014 | Technics Audio Players & Recorders
Low sound from speakers sl1600 auto turntable.. preamp needed? Possible bad Rca's?
No. The RCA jacks are fine. Most likely, you are not using an amplifier with a PHONO input. A CD, DVD, AUX, etc.input if used, will give you a very low sound and poor frequency response(sounds tinny and low). You will need a PHONO preamp that can raise the output of the turntable to match that of the higher level, 300mv inputs mentioned above and have correction for the RIAA decoding to make the music sound correct. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 20, 2013 | Audio Players & Recorders
I want to hook up a turntable to my Nakamichi AV-500 but don't see phono jacks. How do I do that?
if your turntable has an integrated amplifier you connect it directly to any regular input like DVD or CD. If this is a classic turntable you need to buy external phono amplifier. It is a small box with phono inputs and rca regular outputs you plug your turntable trough this box to cd or dvd input of the receiver. Can be tube or transistor amplifier. price vary from 20 to hundreds dollars.
Oct 14, 2013 | Audio Players & Recorders
What do i need to hook the Stanton T.80 up?
Turntables are simple if you've an amplifier with inputs labelled PHONO (not to be confused with audio plugs called phono or RCA)
If your amplifier hasn't then the sound from the cartridge on the arm won't be good quality.
To make it compatible with a line input usually labelled either that or AUX you'll need a phono converter box. There are quite high price ones but there are equally mid and even low-ish priced ones too.
Look around online for Phono-to-Aux adapters, converters or whatever description and/or visit electronic stores like Radio Shack (still in the USA) or Maplins (UK) if you're near any.
Sep 21, 2011 | Stanton T.80 Turntable
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Apr 29, 2017 | Cyberhome CH-DVD 402 DVD Player
Can I hook up a photo turntable to a sony str-de435 receiver? There aren't any jacks that specifically say phono, so I'm wondering if I can just hook it up to any of the audio jacks without any problem....
If your turntable has an amplified output, go ahead and plug it in to the aux port. If not, you won't be able to use it with your receiver properly. Look on the back (or front) of your turntable for a knob labeled "level" or "volume", and that will determine if it's amplified or not. Good luck, I hope this helps!
Oct 19, 2009 | Sony STR-DE435 Receiver
How to wire a numarkdm1600x amp
Power amplifiers usually has only single input RCA input left "white" right "red". The preamp has plenty of input and output jacks, the proper connection is the one labeled "PREOUT" which usually located far from the group of rca jacks "PHONO,TAPE MON. REC OUT" etc. try it, it doesn't harm anything
Aug 09, 2009 | Audio Players & Recorders
I have Pioneer Amplifier with Phono Inputs. Also I have an Akai stereo Equalizer. I want to connect my Turntable to the pioneer amplifier through Akai stereo Equalizer to have a better sound quality. Is it...
hook the turntable "directly" up to the "phono" inputs. if it sounds normal this way, and not loud and distorted, then you have to plug the turntable up that way, directly to the reciever's phono input.
you can hook the eq up through the "tape in/out" jacks.
take the tape record out jacks, and hook them up to the input of the eq, and take the tape play input jacks and hook them up to the output of the eq. then, to use toe eq, select whatever input you want eq'ed, while also selecting "tape monitor"
Mar 07, 2009 | Kenwood Audio Players & Recorders
Trying to hook up amplifier to after market 6by 9 using factory radio
You can not connect the speaker lines directly to the RCA inputs of your amplifier. But you can connect them to your amplifier if your amp has a high level input. Most of the time it looks just like the speaker jacks of the amp, but smaller. It will be labeled high level input or speaker input. Sometimes an amplifier will have a jack for a wiring harness just for this purpose. Some amplifiers have them and some don't.
If your amplifier does not have them, you can purchase a line level adapter at most anyplace that installs car stereos. it converts the speaker level to the proper level of the RCA input.
Just follow the instructions on how to connect it.
If you try to connect the speaker outputs directly to the RCA input of the amplifier you will blow up the pre-amp in your amplifier.
I hope this was helpful to you, if so a good rating is always appreciated.
Thanks and let me know if you need more help.
Jun 20, 2008 | Car Audio & Video
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
128 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
