My nano is on but it shows that its locked. i press any button but nothing works. it shows the song that i was listening to and says that i put it in pause.
    Problem Solver:
  • 18 Answers
Basic thing you should do.
Restart your ipod.
Press&hold the center&menu button to restart it.
if the same thing happens then i think you should restore your ipod.
if you plus in the usb cble from you ipod to pc or whatever but its not showing up on itunes.
Flick the hold switch about 7 times press&hold the center&menu button. When you see the apple mark/picture fade&comes back on quickly press&hold the center&play/pause button.
then that it when its good for you to connect it to itunes.
-if you have any futher questions, come by&ask me and I will do my best to help you!
Posted on Jun 28, 2008
Volume wont turn up on my mp3 - volume too low
How to Reset the Volume Limit on the iPod Nano
Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume.
Instructions
1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
3 Select "Playback" from the menu choices that show up.
4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on.
5 Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Tips & Warnings
If you set up a combination and forget it, you can reset your iPod Nano and start over again. Resetting will not lose any of your downloads, but you will need to restore or reset many of the settings you initially chose when you first set up your iPod.
Changing the volume limits on your iPod Nano covers everything on your player, but the sound levels for songs, audio books and shows will vary based on how they were recorded.
Dec 10, 2011 | Apple iPod nano
My ipod nano froze while i was listening to my music so i restarted it by holding the center button and the menu button. now all it shows is the apple on my screen. when i press play, i can hear my music...
Try going in itunes, right clicking on the song, and click create AAC version. The song may be in the wrong format which is why it won't finish playing it. Hope this helps!
Feb 20, 2010 | Apple iPod nano 5th Generation
IPOD FROZEN
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Apr 07, 2009 | Apple iPod nano
Buttons on my nano do not work
Try a software reset, hold the center and menu buttons for about 5 seconds. If this does not work try a restore through itunes. This solves 99% of ipods problems.
Jan 10, 2009 | Apple iPod nano MP3 Player
2nd gen nano not synching
Put it on autosync or tick all the box's songs you want and manually press sync button on the right bottom corner.
Make sure ur ipod is plugged in
Aug 20, 2008 | Apple iPod nano
Ipod Nano 3rd Generation volume problems
ITunes contains a volume leveling program that works with every recording in your library or you can select each one individually by going to the library, selecting get info with the right mouse button, select options, and change the volume with the control you see on the screen and press ok.
Aug 17, 2008 | Apple iPod nano 3rd Generation
My ipod...is not working correctly...
i dont know how for you to fix it yourself, but if you have your warrienty on it still id get it fixed
Jun 23, 2008 | Apple iPod nano
Nano shows song playing but nothing happens
Make sure your headphones are working properly by testing with your computer headphone jack.
Is the headphone port on the Nano loose?
Connect the Nano to your iPod dock and see if you can head audio through the docks headphone jack.
If the headphones work, and you can get audio out of the dock headphone port, then there is a problem with your Nanos headphone jack.
Apr 07, 2008 | Apple iPod nano 3rd Generation
Ipod
Assuming it's charged, and you have not tired the reset procedure you should.
Using the hold button on the top, put it on hold and then back off. Now press and hold both the Select (center button) and Menu button at the same time. Be patient it can take a long time for the reset to work.
If this does not work and it is charged then you've got bigger problems. My nano does not lock up often, but it does happen.
Good luck...I hope this helps.
Jan 12, 2008 | Apple iPod nano
Ipod nano
You need to do a reset.
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Jan 06, 2008 | Audio Players & Recorders
26 people viewed this question
 Grubhead
Grubhead
