Question about Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor
How get normal images instead of stretched images in wide monitor?
My pictures are all stretched sideways; what settings to achieve regular view?
jkuhn1917@aol.com
How to get normal images instead of stretched images...
Posted on Jan 01, 2009
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
How can I get full screen image without distortion on tv viewing? I only get 4:3, zoom, full and justified. Full looks stretched horizontally with tv, looks ok with dvd.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
Oct 19, 2010 | Panasonic Televison & Video
DISPLAYS ARE SIDEWAYS STRETCHED
This problem is because, when you formatted your PC, you have installed improper display driver of your PC model. This is also because of less capacity display/graphics card.
Jul 30, 2010 | Compaq Computers & Internet
How to change the picture format on my monitor?
You should set your PC to the monitor native resolution for this monitor: 1440 x 900 @60Hz.
Here is the spec for your monitor: http://www.dealtime.com/xPO-AOC-919Swa1-Black
Jan 27, 2010 | AOC 919Swa1 - Black 19 inch LCD Monitor
How do I adjust my emachine monitor to display a more realistic picture. It is too wide and stretched out.
Check your graphics/desktop settings for the screen resolution - it should be set to the monitor's native resolution, which is 1024x768.
Dec 03, 2009 | E-Machines eMachines Monitor E15T4
Stretches images sideways
It would appear that you managed to press CTRL + ALT + Left Arrow.
To correct this problem simply click CTRL + ALT + Up Arrow.
May 07, 2009 | Dell SP2008WFP 20" LCD Monitor
Monitor installtion
Hi Robin,
Hope this instruction well do solve like I met some problem like this. Try to reset the monitors setting manually in OSD (on screen display) mode. Look for frequency settings start at lower and have test it all. Respectively try to configure the video card frequency settings at Operating System GUID (Graphics user interface display) video card setting properties. Start from lower frequency and notice the each changes. When perfectly proportionate select Apply settings.
Best regards,
Rosener Guyano
Nov 13, 2007 | ASUS VW192S Monitor
How do I get the widescreen monitor to show unstretched images?
i had the same problem with my new widescreen monitor... turns out the best setting (at least, for my specific monitor) was 1440 by 900 pixels. at this setting the desktop still stretches itself to fill the entire screen, but everything else is completely unstretched. (to adjust the screen resolution, right click anywhere on the desktop, then go to properties, then settings.)
Nov 07, 2007 | Gateway FPD2275W LCD Monitor
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
Shows as widescreen instead of normal view
try using the tv remote to change the screen size and keep changing it until you find the correct size
Oct 21, 2007 | Pioneer DV-525
Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor Logo
444 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
