Question about Performance Teknique ICBM-771 Car Audio Amplifier
Performance Teknique ICBM-771.
What are the fuse sizes for this amp and why does it keep poppin fuses the same one i took out is the same one i put in what can i do about this
Probly your ground isnt connected right or yor spaekers are probly not connected right recheck and check if the ohmms set on your speakers your amp probly ant handle it
Posted on Feb 19, 2009
I Hooked up a Performance Teknique 1200 watt 2 channel amp to my 2 12" comp kickers. and before doing all this i took out the fuse. from my car battery. after everything was hooked up i put the fuse back...
disconnect the amp and then put the fuse in.if it blows,there is a pinched wire causing a short.
Also,big amplifiers like that have to be wired battery direct.
the surge current at boot up can pull 100 amps for 10 millisec.
Jan 13, 2010 | Performance Teknique ICBM-892 Car Audio...
Keeps on diagnostic after i turned it on and had it completely wired what should be the problem
have you checked the power ant wire? usualy oarnge this needs to be hooked to a power source that is not on when the power of your vehicle is not on (usualy a fuse block)
May 11, 2009 | Performance Teknique ICBM-895 Car Audio...
Performance teknique icbm-782 amplifier will not power on
run 12 volt into your rem terminal and see if it comes on if it does your remote wire coming from the headunit is bad or cut
Apr 15, 2009 | Performance Teknique ICBM-782 Car Audio...
Wont power on after checking all the wires
HI DUDE PLS CHECK UR REMOTE WIRE IN UR PLAYER .... U MIGHT BLOW THE FUSE .. ... THE CONNECTION IN REMOTE WIRE WILL POWER EVEN THE FUSE BLOW ..
Performance teknique icbm 892 1200 watt amp
DD, JL and pioneer in that order. I don't recommend any particular size but 12s are a good compromise.
Sep 21, 2008 | Performance Teknique ICBM-892 Car Audio...
Performance teknique icbm-896 stick on diagnostics
If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Sep 10, 2008 | Performance Teknique ICBM-896 Car Audio...
Diagnostic light comes on only
Probably a short in the circuitry. I would try and check all my wiring to speakers for shorts. If you still cannot get the unit to come up you will probably need to get the AMP serviced unless your pretty good with a meter.
May 28, 2008 | Performance Teknique ICBM-771 Car Audio...
Wont work
If you were blowing an inline fuse, what size was the fuse and how big did you go up? It's possible the has a short in it.
Sep 26, 2007 | Performance Teknique ICBM-780 Digital...
Performance Teknique ICBM-771 Car Audio Amplifier Logo
233 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Jose Velazquez
Jose Velazquez
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
