Cucina Pro Double Coffee Brew Station 1711 Series We have had this unit for about 2 months. It has been operating fine until about a week ago when the left side ON/OFF light and the TIMER light have both started blinking in unison. We have tried reprogramming everything as well as unplugging the machine for a half hour. No luck. The right side is still working without a hitch. Can't seem to find anything about it online and the manual has no trouble shooting section... Thank you!
  • ExplorGM Jun 28, 2008
    Need more selections for areas to select from ? Heating and Cooling obviously is HVAC, not other heating. Sorry.
It is an indicator that means you have to clean that side - you then press two of the buttons for 5_10 seconds to stop the blinking . but i can't find my manual and can't figure out which two buttons!
Posted on Jul 25, 2008
The EES00 voltage is 220-240V 50Hz Our current is 220V 60Hz Can it be used?
usually it will work,but if it has a timer or clock on the unit the time will be fast due to the frequency difference,but all else should work fine
Mar 27, 2011 | Electrolux Cucina Pro 1711 10-Cup Coffee...
Brewing wrong cup size and sometimes will not brew at all
In Uk i would take it back to shop as faulty and get either replacement or full refund as it is not fit for purpose. Depends where you live and what consumer rights you have.
Mar 23, 2017 | Keurig Platinum B70 Coffee Maker
Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Mar 12, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Drip Drawer will not release
Hi
They can get sticky at times but there is no real reason for it to be jammed unless its taken a bit of a bang on the metal base of the unit at the front left. Mine was the reverse when I got it - could not get it in properly until I realised the left edge was bent in a bit.
Suggest you remove the 'grill' top of the tray, mop up all water in there. Get someone to hold the whole unit steady while you give it a good pull out and slightly up. Then you can remove the used coffee bin and then the brew unit. The former will need emptyimg when the message comes up and the brew unit ( vertical grey object inside door) it should be cleaned with warm water at least once a week to save that gumming up with coffee goo also.
If you need a manual contact me.
Feb 08, 2009 | Saeco Royal Professional Espresso Machine
Cucina pro double coffee maker
i have the extra carafe, i need one too but cant find one, so you can have mine.
respond to elizabethstacey@comcast.net
Dec 16, 2008 | Coffee Makers & Espresso Machines
I have the cucina pro double brew coffee maker and have a broken carafe....how do I get a replacement carafe?
I have found a temporary solution! Mr.Coffee Replacement Decanter model # ECD13 will work if you take your old over and use it with this decanter. The lid that comes with the Mr Coffee is just a hair to short but the lid from the broken craft will work well with it. Just hold on to it when you poor your coffee. I hope this helps.
Dec 16, 2008 | Electrolux Cucina Pro 1711 10-Cup Coffee...
No coffee, water going to the drip tray
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 20, 2008 | Saeco Royal Professional Espresso Machine
SAECO VD
If you take out the brewing unit and look in the chassis you can see a hole, make sure that hole is clean.
Jul 25, 2008 | Saeco Vienna De Luxe Espresso Machine
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
