Question about Compaq ( 277498-001) Motherboard
Maximum RAM supported
I am trying to find out what the maximum amount of RAM is supported by the compaq EVO D500 1.8 ghz. pentium 4 mainboard. I haven't been able to get any information from HP.
    Sergeant:
    Champion:
  • 417 Answers
YOUR IN LUCK I JUST WORKED ON THIS VERY SAME MOTHERBOARD MAX RAM FOR *********** BOARD IS 4GIGS BUT ALL YOU REALLY NEED FOR A GOOD FAST WORKING COMPUTER IS AT LEASE 1GIG
Posted on Jul 02, 2008
Compaq system board 686,0MB (320756) board manual
That's an old mainboard (Motherboard), used in a Compaq Presario 5716 desktop computer. (And perhaps a few other Compaq Presario's)
1) Uses a Slot 1 (Intel) processor slot.
http://en.wikipedia.org/wiki/Slot_1
2) Maximum Intel Slot 1 processor that can be used, is an Intel Pentium III, with a 100MegaHertz Front Side Bus. (100MHz FSB)
Maximum frequency rate for the processor is 700MHz.
('Speed')
http://www.cpu-world.com/CPUs/Pentium-III/TYPE-Pentium%20III%20%28Katmai%29.html
(Scroll the page down)
3) Ram memory is SDR Sdram at 100MHz. Or also known as PC-100. (168 pin. 82 on each side. Two Locating Notches on bottom. Commonly just known as Sdram, but that is a misnomer)
http://en.wikipedia.org/wiki/PC100
Maximum TOTAL Amount of ram memory is 384MegaByte.
Maximum Amount for each ram memory slot is 128MB.
There are 3 ram memory slots.
4) Do not know what the jumper settings on the motherboard are.
5) Do not know what the Front Panel header pinout is.
6) Can run Windows XP Home Edition, but do not expect a world of performance.
Regards,
joecoolvette
Jun 10, 2012 | Compaq Computers & Internet
Does Intel Pentium 4, 2 GHz Processor support 2GB DDR1 RAM..?
Type of RAM supported has nothing to do with the processor make & type in most cases. It is more important to verify that the motherboard supports this kind of RAM.
In general, most motherboards supporting the Intel Pentium 4 2.0 GHz processor support also DDR1 RAM.
Sep 05, 2011 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Too slow Compaq Evo Pentium 4 1.60 GHz 256 MB of RAM
Try re-install the operating system . If windows xp you wanted, try using the first/SP1.
Most of all older machine with low spec,mostly slow . but not that slow if choose the right system operation. i suggest try install windows 2000 for better performance.
akee.4shared.com
Aug 15, 2011 | Compaq EVO PIII 1.0 GHZ 256 RAM 20GB HD...
I want to upgarde my compaq evo n1000c laptop. i want to increase my processor and graphic card, can it happen ????
Not graphics card, sometimes the processor although HP are usualy keen on intergrating it onto the motherboard...so in short..NO!
Mar 17, 2011 | HP Compaq Evo Notebook N1000c
Ecc ram in compaq Evo d300 won't work, is there a Ram setting in bios?... updated bios to 3.04
Hello mike59087, if you are having a problem with the 'RAM,' you should check to see if the 'System' support "ECC RAM." Next check to see if ie; you added more 'RAM' what type of RAM did you have in the computer before. You should see if the System is compatible with the different "Type: DDR, DDR2, DDR3, 512MB, 1GB, or 2GB; what is the [Maxium] RAM supported? Are the "Speeds different? 333Mhz, 2.1 GHz, 3.2 GHz... Is the RAM, Dual Layer, Double-sided... For the 'best performance; all RAM should be the 'same speed, from the 'same' manufacturer, the "total amount to add up to the "Maxium" supported RAM, and the 'same type: DDR, DDR2, or DDR3... Take a look at this website, it will give you a "quick scan, to see the type of RAM that is best to use with your 'system. "Thank for using Fix'Ya, and if this helped at all; click on the "Thumbs Up" to give a rating, thanks again, paul7of 9." Click Here: http://www.crucial.com/?gclid=CPqRvfLG4qUCFaVx5QodTzoM1A&cpe=pd_google_us&ef_id=ba5NApFYAQAAxxw:20101210204512:s
Dec 10, 2010 | Compaq (281946-001) for Evo D300...
Maximum ram soze of my Intel® Pentium® Processor E2140 1.60 GHz?
The Pentium Dual-Core has a theoretical maximum address size of 256 TB. The actual amount of RAM you will be able to use with it depends on the chipset, BIOS, and motherboard.
Aug 16, 2010 | Intel Pentium Dual Core E2140 / 1.6 GHz...
Compaq EVO 510 2.4GZ Motherboard Question
YOU MAY HAVE TO CALL HP /COMPAQ TO SEE IF YOU HAVE THE RIGHT MOTHER BOARD FOR THAT PC
Jan 08, 2010 | Compaq Evo D510 Minitower (Open Box)...
My evo is running slow, i was thinking of upgrading the ram. what type of ram and what is the max?
mine was running slow too. Like I'd turn it on and go grub some coffee, than make some toast and then after It'd bring the windows screen on.
If that's the case I suggest to try different hard drive, but my guess it's motherboard issue:
Here is memory information for EVO D51. Please let me know what model you have, so I can be more specific
RAM Memory Specifications
Memory Speed: 133MHz
Memory Type: SDRAM (PC133)
Maximum Memory Supported: 1.5GB
Memory Slots (Total): 3
Oct 08, 2009 | Intel Compaq EVO Pentium 4 1.7GHz / 256MB...
40gig hard drive pentium 4 2.4 ghz processor.
http://www.newegg.com/Product/Product.aspx?Item=N82E16829126005
Not great quality, but cheap. Should work fine with your computer.
Jun 25, 2009 | HP Compaq EVO D51S Intel Desktop PC -...
Cpu support
hi,
It will be supporting till 1.6 ghz pentium if u will put a processor from outside
Mar 03, 2009 | HP Compaq Evo D310 PC Desktop
Compaq ( 277498-001) Motherboard Logo
149 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
