Question about Coleman Heating & Cooling
We canot find the replacement for our heat pump DRHS0361BB
I can't find a direct reference for the number you entered.
I suggest you Email Coleman to clarify your request - just click HERE for their contact details.
If you specify which part is needed, I can assist further.
Thanks for using Fixya!
Posted on Jun 28, 2008
Coleman eb23b, I canot get my ac unit to kick on, i just replaced the relay, sequencer, thermostat and transformer. i am not getting low 24 vac to my relay.
Gotta find where 24 stops. Possibly blown fuse, possibly losing your common. Check the 24 at relay to ground rather than both relay coil terminals to test common. Jump straight from transformer to relay to ensure that's what's happening.
Jun 12, 2017 | Coleman Heating & Cooling
I REPLACED MASTER CYLINDER AND SLAVE BUT CANOT GET CLUTCH
Some clutches can be fearsomely difficult to bleed successfully. In cases of difficulty it is worth trying reverse bleeding...
Connect the clutch bleeder and the nearest brake bleeder together with some well-fitting tubing, open both bleed screws and have an assistant pump the brake pedal. Make certain the brake reservoir is kept topped up and remove excess fluid from the clutch reservoir before it overflows.
Half a dozen pumps usually is sufficient, hold the pedal down and close both bleed screws.
May 05, 2014 | 1994 Isuzu Pickup
The windshield washer does not work. The wipers do. We know it is not frozen. Also canot hear the washer motor running
washer pump sounds like it is burnt out check to see if there is power going to the pump if so replace pump
Dec 29, 2010 | Dodge Caravan Cars & Trucks
My dryer is not heating up. I change the heating ele and still not heating up?
The problem is with one of the thermostats or thermal fuse a simple continuity check will find the faulty tstat. Check the video on replacing a heating element it will show you how to check these other fuses. This is not the same model but the testing will be the same.
www.appliancehelponline.com/servicemanual.html
Hope this helps
Mar 24, 2010 | Amana ALE643RB Electric Dryer
Canot read after refill
You need to shop online for either a chip resetter or replacement chips. You can't refill Canon inks without a new chip because the chip tells the printer that the ink is empty even when you add more ink.
Jan 19, 2010 | Canon PIXMA iP1600 Printer
Changing the fuel pump any advice? Can I change it without removing the tank where the pump is on the front of the tank?
generaly if the fuel pump is in the tank it canot be removed without removing the tank.
Nov 19, 2009 | 1993 Lincoln Town Car
My yellow catridge still canot resetter after i replace & change
Hello sir; First thing have to do is make sure you put the cartridge in right way, after you installed the cartridge you have to press resume key.
Apr 17, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Heating & Cooling Logo
76 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
