Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Bosch dishwaasher installation
I have just bought a second hand Bosch diswasher and the grey waste pipe that comes out of the machine has a "knob" on the end that is too small a diameter to fit onto the horn attachment under the sink. I have looked in the DIY shops and can't find an attachment that fits under the sink with a smaller diameter. Am I missing something, or do I just cut the "knob" bit off to leave the corrugated plastic which "should" fit on the horn?
Trouble is, once I've cut it off, there's no going back!
  • Lottieuk Jul 24, 2008
    Thanks - I contacted a local store and they came up with a similar solution, a piece of rubber pipe and two "jubilee" clips.
I have overcome the problem by fitting a old style hose fitting (non threaded taps) for garden hoses (rubber end with built in clamp)and clamped it on to the hose and then onto the drain pipe. Available Bunnings for $10.00
Posted on Jul 24, 2008
I have a Bosch washer that doesn't drain, i changed the pump and it still doesn't drain. Could the pressure switch be the problem. If not what can I do? Bosch 800 series
Open filter go to back of machine & clean the end of grey waste pipe blow into end of pipe, if u feel no restriction when blowing their is no blockage next tilt machine backwards at 45 degree angle against wall the u can look under washing check large black waste water pipe between bottom of drum and water pump for possible blockage make sure u isolate machine from electrical supply first hope this helps
Mar 29, 2016 | Bosch Washing Machines
Fit a new waste pipe?
you need to lay the machine on its side
this is the oposide side from the soap drawer
then under the machine locate the pump and remove the pipe from the pump
must use a spring clip youll need a good set of plyers or a pair of gas grips etc to squeeze the clip open
then the pipe will come out from its hole easily
Dec 04, 2014 | Bosch Classixx WFL 2462 Front Load Washer
Bosch 500 series error E13 can't get to the front pump
make sure the machine is unplugged,, turn water hose off and undo it from the machine.. then undo the waste pipe now pull machine out and lay a cushion on the floor at the back of the machine.. lay the machine on the cushion (so its on its back) undo one screw bottom end near pump on plimpth and push plimpth to the right and once off you will see 3 screws around the pump,, undo them and pump should fall down,, now you have the pump in your hands it should unscrew,, take out all the **** from the pump,, once you have cleared everything you should put everything back together.
Oct 19, 2012 | Bosch Nexxt 500 Plus WFMC5301UC
Bosch EXXCEL 1400s. Clothes have a horrible damp smell when they come out of the washing machine. have clean and washed out all pipes but sill a damp smell inside machine. What is wrong with it? So bad...
yes,,,,,1 coup of soda crytal
1 coup of any vinegar
1 coup of diswasher salt
put it on 90 degree empty wash..........and see the result.....
my name is khan.
Apr 06, 2011 | Bosch Exxcel WFX 145S Front Load Washer
Hi i have just bought a second hand whirpool washing machine, its in good nick. Just wondering how to insatll it. We have the waste hose which is connceted to the machine and two connections at the top....
Blue is cold red is hot...If you only have one cold feed pipe you can buy adaptor Y piece that allows both pipes to be connected , The drain of course goes into sink waste...Hope that helps
Oct 01, 2009 | Washing Machines
I have a bosch dishwasher that wont drain
Question! Did u buy this from Bosch? If you did not, then your contract is with the Store you bought it from and NOT Bosch and you should be contacting them and they should sort the problem.
A blockage, can sometimes be solved by putting one of those diswasher cleaning tabs in the machine a couple of times and see if that sorts the problem for you.
I suggest do that first it is the cheapest option and then if that does not work ring who you bought it from whether that be a retailer or Bosch themselves.
Jun 18, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Cant connect the water hoses the machine
Cold fill only , designed to run efficiently on lower temperatures and with cold water powders
Blank off the hot supply line at the back of your washer before you fit it back to the wall.
Only two pipes on the machine Cold In, Waste out
Apr 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Hooking carbage disposal to diswashing not sure where it hooks on the dishwasher itself
Waste line from dishwasher to waste connects to one of
  • small spigot on extension pipe above the disposal up high under counter
  • small spigot on side of disposal directly above sewer connection, below blade
  • small spigot on sewer line below disposal, but above U trap
at the dishwasher end, the hose connects to the pump output, under the base of the dishwasher, usually left side of center, there is no external spigot
you have to run the waste line under from the back, and connect from the front , by removing the kick plate under the door opening
Oct 30, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Spots of Grey lint left on clothes after washing
Have you cleaned the filter on the front bottom of the machine?
May 11, 2017 | Bosch Washing Machines
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
144 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
