Question about Samsung LN-T4665F 46 in. LCD Television
READING CODES i was once told from a technician that you can read codes from the little standby light (indicator) on the bottom right side of your tv. i was told the number of times it blinks, when you have just turned on your tv, shows what's wrong with it, is this true ? and if it is where can i get the manual that states the problem !!!
    Genius:
  • Samsung Master
  • 1,689 Answers
If you can order the shop service manual from Samsung the codes for this should be listed. Even if you had the codes, you would not be able to service the set yourself without the proper facilities, tools, training, and experience as a TV tech.
I found that sometimes you can get a code, and then it is only a leader in to some other types of faults. There are times when there are no codes for a fault, because the main power supply has also failed, and or there is a fault with the main processor area.
In the end, the sets have to be troubleshooted and serviced following the schematics and using a DVM, scope, and diagnostics.
Jerry G.
Posted on Jun 28, 2008
I have a black screen, nothing showing up at all, what i should check?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 24, 2016 | Samsung 50 in. Plasma TV
What does a red blinking light on the bottom right corner of the TV mean?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nov 28, 2014 | Ario HC3269 32" LCD TV
Ma12410049
Aug 30, 2014 | Televison & Video
Flashing light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Unlike other brand TVs, reading the blinking codes to Philips is different. Check the linked site by type in 'Philips' at its search box, and press Enter.
Apr 14, 2014 | Philips 32PFL5403 LCD TV
Technika 22-700 standby light flashing
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 25, 2013 | Televison & Video
Standby light blinks and tv wont cut on
How many times the standby light at its front panel blinks? Count it. These blinks are fault indications. Check this link for more details about Sony Blinking codes. Count the blinks that occur once, after switch the TV On by its front panel power switch. Check it.
Jan 02, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Check engine light for volvo 850 wont go off wat else can be the problem if i got a full tune up and put in new spark plugs plus it trembles alot and it shakes when i start it up plus wen i put it on...
Hi, I recommend you access the OBD panel to extract the trouble codes. Then send us the trouble codes for further advice. On 850 models the DLC is located in the engine compartment in front of the module box, behind the passenger side headlamp.
  1. Open diagnostic socket cover and install selector cable into socket No. 2 for fuel injection codes or socket No. 6 (except Motronic systems) for ignition codes.
  2. Turn the ignition switch to the ON position.
  3. Enter control system 1 by pressing the button once. Hold the button for at least 1 second, but not more than 3.
  4. Watch the diode light and count the number of flashes in the 3 flash series indicating a fault code. The flash series are separated by 3 second intervals. Note fault codes.
1f there are no fault codes in the diagnostic unit, the diode will flash 1-1-1 and the fuel system is operating correctly.
  1. If diode light does not flash when button is pressed, or no code is flashed there is a problem with the soft-diagnostic system, proceed as follows:
    1. Check ground connections on the intake manifold, and the ground connection for the Lambda-sond at the right front mudguard.
    2. Check the fuses for the pump relay and the primary pump. On 240 models, fuses are located inside the engine compartment on the left side wheel well housing. On 760/780 models, fuses are located in the center console, just below the radio. On 740/940 models, fuses are located behind the ashtray. Access can be gained by removing the ashtray, and pressing upward on the tab marked electrical fuses press. On 850 models, the fuses are located on the left side of the engine compartment behind the strut mount plate. The fuses on 960 models are located on the far left side of the dashboard. The driver's door must be open to gain access to the fuses.
    3. Remove glove compartment, and check control unit ground connections.
    4. Turn the ignition switch to the OFF position. Remove control unit connector and connector protective sleeve.
    5. Check diagnostic socket by connecting a voltmeter between ground and No. 4 connection on the control unit connector. Reading should be 12 volts. If no voltage is present, check lead between control unit connector and fuse No. 1 in the fuse/relay box.
    6. Turn the ignition to the ON position, and install selector cable into the No. 2 socket on the diagnostic socket. Connect a voltmeter between ground and No. 12 connection on the control unit connector. Reading should be 12 volts. Press the button on diagnostic socket and note reading. Reading on the voltmeter should be 0 volts. If no voltage at the control unit is present, take reading at the diagnostic socket connector. If reading remains at 12 volts when button is pressed, check diagnostic socket.
    7. Connect a voltmeter between ground and the red/black lead on the diagnostic socket connector. Reading should be 12 volts.
    8. Connect a suitable ohmmeter between ground and the brown/black lead in the diagnostic socket connector. Reading should be 0 ohms.
    9. Turn the ignition to the OFF position. Connect ohmmeter between diagnostic socket selector cable and the pin under selector button. The ohmmeter should read infinity. Press the button and note the reading. The reading should be 0 ohms.
    10. Connect a suitable diode/multimeter tester, or equivalent, between the diagnostic socket diode light and the selector cable. Connect red test pin from the tester to pin under diode light and black test pin from tester to selector cable. A reading on the tester indicates correct diode light function. With no reading on tester, replace diagnostic socket.
    11. Check the system relay/primary relay by connecting a voltmeter between ground and the No. 9 connection on the control unit connector, then connect a jumper wire between ground and No. 21 connection on the control unit connector. The relay should activate and the reading should be 12 volts.
  2. Press the diagnostic socket button. Note any additional fault codes.
The diagnostic system memory is full when it contains 3 fault codes. Until those codes are corrected and the memory erased, the system cannot give information on any other problems.
  1. Press the diagnostic socket button for the third time to see if a third fault code is stored in the memory. If the diode light flashes the same code 1-1-1, there are no other codes in the memory.
Fig. Fig. 1: Push button once for mode 1
Push button twice for mode 2
Push button three times for mode 3
To clear the codes:
  1. Turn the ignition switch to the ON position.
  2. Read fault codes.
  3. Press diagnostic socket button 1 time and hold for approximately 5 seconds. Release button. After 3 seconds the diode light should light up. While the light is still lit, press the button again and hold for approximately 5 seconds. After releasing the button, the diode light should go off.
  4. To ensure that the memory is erased, press the button 1 time, for 1 second but not more than 3 seconds. The diode light should flash code 1-1-1.
  5. Start and run engine. If engine will not start, correct the problem before proceeding and start over with Step 1.
  6. Check to see if new fault codes have been stored in the memory by pressing the diagnostic socket button 1 time, for 1 second but not more than 3 seconds.
  7. If fault code 1-1-1 flashes, it indicates that there are no additional fault codes stored in its memory.
Oct 05, 2011 | 1994 Volvo 850
Active faults 1 at startup screen
if you press and hold the mode button it should beep then you will get the component location. ecu 128 for example is in the engine- mid 136 is the abs. once you see that, press the mode button again and you will get the code. sid 123 for example- press mode button again and you will get the failure code. FL 02, could indicate when it is reading a high or low reading, short or open... etc. once you have the three parts of this code then you should be able to contact your local dealer to find out what the code means. Truck diagnostics are not always easy... active codes really just give technicians a place to start... hope this helps
Dec 16, 2009 | RTO Ho Herpa Freightliner Truck Tractor
Reading computer codes
The Assembly Line Diagnostic Link (ALDL) connector or Data Link Connector (DLC) may be located under the dash and sometimes covered with a plastic cover labeled DIAGNOSTIC CONNECTOR.
  1. On all 1990–95 models the diagnostic trouble codes can be read by grounding test terminal B. The terminal is most easily grounded by connecting it to terminal A (internal ECM ground). This is the terminal to the right of terminal B on the top row of the ALDL connector.
  2. Once the terminals have been connected, the ignition switch must be moved to the ON position with the engine not running.
  3. The Service Engine Soon or Check Engine light should be flashing. If it isn't, turn the ignition OFF and remove the jumper wire. Turn the ignition ON and confirm that light is now on. If it is not, replace the bulb and try again. If the bulb still will not light, or if it does not flash with the test terminal grounded, the system should be diagnosed by an experienced driveability technician. If the light is OK, proceed as follows.
  4. The code(s) stored in memory may be read through counting the flashes of the dashboard warning lamp. The dash warning lamp should begin to flash Code 12. The code will display as one flash, a pause and two flashes. Code 12 is not a fault code. It is used as a system acknowledgment or handshake code; its presence indicates that the PCM can communicate as requested. Code 12 is used to begin every diagnostic sequence. Some vehicles also use Code 12 after all diagnostic codes have been sent.
  5. After Code 12 has been transmitted 3 times, the fault codes, if any, will each be transmitted 3 times. The codes are stored and transmitted in numeric order from lowest to highest. NOTE: The order of codes in the memory does not indicate the order of occurrence.
  6. If there are no codes stored, but a driveability or emissions problem is evident, the system should be diagnosed by an experienced driveability technician.
  7. If one or more codes are stored, record them. Refer to the applicable Diagnostic Code chart in this section.
  8. Switch the ignition OFF when finished with code retrieval or scan tool readings. NOTE: After making repairs, clear the trouble codes and operate the vehicle to see if it will reset, indicating further problems.
Jul 05, 2009 | 1992 Cadillac DeVille
Samsung LN-T4665F 46 in. LCD Television Logo
221 people viewed this question
Jerry Greenberg
Jerry Greenberg
