Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
How about this method?
It should be much easier to refill. No spill, no mess, very fast.
It's ROADINK....
HP Deskjet F380 Ink Cartridges
HP Deskjet F380 Ink Cartridges C9351, C9352, C6658
AND for other printers like:
HP deskjet 3620v, 3650, 3650v, 3651, 3843, 3845, 3845xi, 3847, 3910, 3915, 3920, 3930, 3930v, 3940, 3940v, 450, 450chi, 450ci, 450wbt, 5150, 5150w, 5550, 5650, 5650w, 5850, 5850w, 9650, 9670, 9680, D1330, D1360, D2330, D2360, F300, F310, F325, F335, F340, F350, F370, F380, F385, F390, HP FAX 1250, HP OfficeJet 4110, 4110v, 4110xi, 4215, 4215v, 4215xi, 4315, 4315v, 4315xi, 5605, 5610, 5610v, 5610xi, 6110, 6110xi, HP PSC 1311, 1315, 1315v, 1315xi, 1350, 1350v, 1350xi, 1410, 1410v, 1410xi, 1417, 2110, 2110v, 2110xi, 2175, 2175v, 2175xi, 2210, 2210v, 2210xi, 2410, 2410v, 2410xi, 2510, 2510xi, HP PhotoSmart 7150, 7260, 7260v, 7260w, 7350, 7450, 7450v, 7450xi, 7550, 7660, 7660v, 7660w, 7755, 7760, 7760v, 7760w, 7960, 7960w, PhotoSmart PSC 2410v.
You have three solutions for your HP Deskjet F380 Ink Cartridges needs.
You can choose from:
- Remanufactured ink cartridges
- OEM ink cartridges
- Refill kits.
If you want to know how to replace hp f380 ink cartridges then look in your printer manual. If you don't have a manual you might follow these directions to change cartridge:
# Make sure your HP All-in-One is on.
# Open the print cartridge door. (the hpf380 deskjet cartridge moves to the center)
# Lightly press down on a print cartridge to release it.
# Pull the print cartridge toward you out of its slot.
# Remove the plastic tape from the copper-colored contacts of the new cartridge.
# Slide the new hp deskjet f380 cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
# Close the print cartridge door.
Description of the cartridges with HP deskjet F380 cartridge number.
Remanufactured:
(as a money-saving replacement for OEM ink cartridges)
Hewlett Packard (HP) C9351AN / C9351A (HP 21 Black)
Remanufactured Ink Cartridge,
Hewlett Packard (HP) C9352AN / C9352A (HP 22 Tri Color)
Hewlett Packard (HP) C6658AN / C6658A (No. 58 Photo)
OEM cartridges:
Hewlett Packard (HP) C9351AN (HP 21 Black) 5ml OEM Ink Cartridge
Hewlett Packard (HP) C9352AN (HP 22 Tri-Color) 5ml OEM Ink Cartridge
Hewlett Packard (HP) C6658AN / C6658A (No. 58 Photo) OEM Ink Cartridge
Ink Refill kits for all-in-one F380 refill:
InkTec Refill Kit for No. 21 Black (C9351AN / C9351A) - Hewlett Packard (HP)
InkTec Refill Kit for No. 22 Tri Color (C9352AN / C9352A) - Hewlett Packard (HP)
InkTec Refill Kit for No. 58 Photo (C6658AN / C6658A) - Hewlett Packard (HP) With these refill kits goes information on how to refill hp deksjet f380 series with ink.
Can also try this link
http://www.fixya.com/support/r9374114-re...
It works well!!
Regards
GM
