Question about Haier Energy Star ESA3183 Air Conditioner
Air Handler Orfice piston
To Whom It May Concern:
I'm having a problem with my central air conditioning. I need to know which direction does the Orfice Piston go in??
My repair person is Patrick.
I would appreciate your answer soon. Thank you.
Darlene Proulx
    An expert who has answered 500 questions.
  • 540 Answers
The part with the white plastic washer goes inside the seat!
Posted on Sep 07, 2008
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
This is a central air conditioning question. I have no power to the "battery-less" thermostat. I have two thermostats in the main house and swapped them out to see if one of the thermostats is bad, but...
Are you getting 24 volts from the thermostat to the transformer in the air handler? Sounds like the transformer in the airhandler. You can check it by taking the voltage from the R termianal to C Terminal and should read 24 volts.
Jun 23, 2010 | Heating & Cooling
The central air handler turns on but the outside compressor does not start. I have checked the breakers...they are on.
Check the condition of the contactor, Check the capacitor, If you have a multimeter, turn the power off and check the continuity of the compressor windings. You didn't say whether or not the outside fan is running. If it is then the contactor is working but look at the condition of the contacts.
Jun 20, 2010 | Heating & Cooling
Air handler too large for heat pump doesnt heat or cool properly any options to get unit to prefrom better like pistons or txv
I would check with the manufacturer and check on the right sized air handler. The txv or piston has been engineered to function with the system you have and this will change the dynamics of your system by altering the metering device.
Jan 06, 2010 | Heating & Cooling
Can somebody help,why is my Central AC blows
Most heat pumps have an auxillary heat. Many are electric auxillary heat with a heat strip in the air handler. A common malfunction is for the electric auxillary heat to operate when the heat pump is set on cool. To confirm this, locate the conductor that runs from the heat sequencer to the connection on the heat strip. You will see this on the top section of the air handler. Use the clamp on part of the amp meter over that wire. If the thermostat is set on cool and the heat strip is drawing amps, it means the heat is coming on while the heat pump is set on cool. There is usually one or two causes for this, either the sequencer is bad or there is low voltage wires usually behind the thermostat or in the air handler closet that are touching that shouldn't be touching.
If this is not the case, if its not a problem of where the heat is coming on with the air conditioner, it could be a case of the reversing valve malfunctioning. The way a heat pump works is it reverses the flow of the refridgerant. For instance, many heat pumps the reversing valve is activated in cool. That would mean that there is a low voltage circuit that activates the reversing valve when the heat pump is in cool. I'm not sure what model/brand your heat pump is, Goodman and Janitrol for instance, the heat pump reversing valve is activated in cool. In any case, if the reversing valve is not operating properly, when the air conditioning is set to cool it will actually be heating. Or you could set it to heat and it may actually be cooling instead of heating. Please check these two items first and if you have any further questions, please let me know. Especially if you know of any additional problems like the evaporater is icing up or if the air handler fan is not operating when it should.
Aug 31, 2009 | Heating & Cooling
Ruud uamc-048jaz
What do you need to know? That is a 4 ton 12 seer straight cool system, with 11 kw heat strip. You may go to to search perfomance data.
Dec 03, 2007 | Ruud Central System Air Conditioner
Haier Energy Star ESA3183 Air Conditioner Logo
101 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
