Phone memory is low that's why its getting stuck,it means,not enough memory may cause malfunction.
Solution are :
* delete unused data or files so there will be a free space on your phone memory and to be able to operate smoothly.
* Reset the phone by this procedure,go to settings > initial set-up > Master Reset or Master Clear
Master Reset - your phone settings will go back to default (no data will be deleted) Master Clear - your phone setting will fully format. (all data of yours will be deleted) and back to original settings.
before doing master clear,be sure all of your important data must be saved before doing this method.
I hope this solution will help you. thank you for visiting fixya.
If you forgot the password or don't know the security code, You have to master reset the phone. Contact your service provider to get a master reset code at free of cost....You can also visit http://www.unlock-zone.com/ and can see different options there to get unlock code for a price. Choose any price appropriate for you.................
Here is how to do a master clear or master reset on most Motorola cell phones.
If you have a Motorola cell phone and want to clear all numbers out of the address book and reset factory settings you need to use the master reset function.
First you need to go to the main menu, settings, setup, master clear option and enter six zeroes, 0000000
This works on most phones. If that does not work call your carrier's technical support by dialing 611.
Master Reset Codes and Master Clear For Motorola Cellular Phones.
var dc_AdLinkColor = 'blue' ;
var dc_PublisherID = 90892 ;
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3: 1. Open your phone up and go to “Settings” 2. Next go to the selection for “Initial Setup” 3. Next go to the selection for “Master Clear” 4. Then select to confirm the option. 5. Now enter the security code which should be “000000” 6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post: hard reset motorolla razr v3 hard reset razr phone wii master reset hard reboot motorazr how to hard reset a razor v3 master reset code for motorola v3 master reset code razr v3 master reset for v3 via pc master reset motorola razr 2 master reset v3 razr with white screen motorola v3m master reset p2k commander razor master reset razr 3 and how to reset razr master reset ebay razr master reset password razr master restart razr screen master reset reset razr reset razr to factory reset razr v3 to factory v3 hard reset razr v3 razr reset hard boot
