Question about Epson Aculaser C1100 Printer
Epson c1100 Hi My printer shows lid B is open even though it is clicking shut [you can hear the switch].Any tips!!!! Thanks in advance. Gerry B.
  • Epson Master
  • 691 Answers
Look for the switch on the rear cover above the fuser. It is often this switch this gets bent out of the way and causes the error.
Get a service manual HERE if you need to take the switch out or see which ones are interconnected
Posted on Jun 28, 2008
Hi when I print out in colour on the epson aculaser c1100, I get a smudge of yellowish pale colour on the right handside of the paper how do we fix this problem
Click here for the manuel. It will walk you through cleaning the cartriges. In most cases using the built in self-clean will take care of the smudge. You can also try removing the cartige and cleaning it and the housing with a damp q-tip or cotton swab.
Jun 07, 2011 | Epson Aculaser C1100 Printer
Service Req E511
e511 is to do with the photoconductor unit which sits under the top lid
usually detector underneath the photoconductor dirty or the wide rubber belt then runs throuigh the photoconductor is sligthly off to one side
Feb 24, 2010 | Epson Aculaser C1100 Printer
No print on the RHS of page using Epson Aculaser C1100
Two things to check,
1- clean the laser by opening the front cover, pull forward the green lever on the R/H side, take off the little panel on the R/H side of the printer and pull out/push in the lens cleaning "stick". Replace panel and push the lever back in, close the front and try a test print.
If that didn't work:
2- Open the lid, lift the orange lever and remove the photoconductor. Be careful with it as it is easily scratched. Inside the printer rotate the toner cartridges and check that the cartridge lock levers are fully locked as even a couple of millimeters can block the laser.
Hope this helps.
Sep 09, 2009 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 E537
Hi there
This suggests a fuser error. This is the hot unit at the rear top of the machine.
Steps are as follows:-
1. Open COVER FUSER.
2. Draw out the COVER RH boss from the hole on COVER FUSER while pushing
COVER RH outward, and remove COVER FUSER.
After removal check coninuity across heater lamp amd thermistor terminals. If either shows anyhing more than 13 Ohms then you need to replace your fuser unit.
Anything more than that requires hands on technical expertise.
Good luck
ivorpits
Dec 20, 2008 | Epson Aculaser C1100 Printer
Epson c1100 printer problem
open the top cover/lid. on the right there should be an orane clip, pull this upwards and then pull the photoconductor unit out by holding the orane handle ontop of the unit.
hope this helps
Oct 16, 2008 | Epson Aculaser C1100 Printer
Epson C1100 Aculaser Duplex unit not recognised by Vista
I have had the problem, but it is easily fixed in Vista.
1. Click Control Panel
2 Click Printers
3 Right click your AL-C1100
4 Click Properties
5 Click Optional Settings label
6 Click - "Update printer info manually"
7 Click - "Duplex Print Unit "
8 Click Settings
9 Tick box in bottom left hand corner - "Duplex Print Unit"
10 Click OK .... exit
Sep 12, 2008 | Epson Aculaser C1100 Printer
I got the info through an Epson Eng I know. You should be able to get a replacement item by contacting Epson directly.
Sep 01, 2008 | Epson Aculaser C1100 Printer
C1100 B Open error
Often, this would just be the sensor falsely thinking that the cover B is still open. You could try checking if the cover is slightly misaligned hence the tab is not triggering the senor/switch. Or try opening and closing and making sure that you hear/feel the latching of the switch.
Better yet, perhaps the parts diagram may be of better help. You would probably be interested likewise in the service manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Epson Aculaser C1100 Printer
Mac OS10.4.11 Epson C1100
I also use a Mac, (OSX 10.3.9) does this printer show up in the list when you activate the Printer Setup Utility (PSU) Do you get any error message from the Mac such as Printing Stopped etc. What shows when you click on the PSU after clicking on print etc.
Jul 01, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
196 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
