Question about Asrock M266A Motherboard
Memory Update Hey, I'm trying to update my pc's memory by installing DDR dimm's. Each One of them has 1GB at 400mhz. When I start the windows it starts going crazy, with all types of errors. Ex: when installing the systems files, it stops everything and gives me blue screen with a lot of errors, specificaly "NTFS.SYS" If I take one of the dimm's off and star all over again it all goes well. What do I do? Motherboard: Asrock M266A Thanks
  • 38 Answers
Looks like u overdosed it ur mobo can spport up tp 2gb at max but u siad each had a gig on them so thts 4 gigs total
also ur mobo supports a max of 1gig on each memory slot so u cant buy a 2gig stick and put it in a slot
Posted on Sep 26, 2008
  • 166 Answers
Hello there.
From your description is sounds like the new Memory is either faulty, or not compatible with your sytem, this explains the error messages and blue screens.
What i would suggest is to download a free program called 'memtest' that you can burn to cd and let your computer load it up before it loads Windows, this will check the memory for any errors and verify that indeed the memory is faulty.
You can find memtest here
Please try this and let us know what happens. If you only purchased the memory then you can get it replaced for free.
Hope this helps.
Posted on Jun 28, 2008
Hi..i have a P4m800-M7 rev 3.1 motherboard which recently had only 1 512MB DDR 400mhz RAM.. itried to install an additional 256MB DDR 400mzh ram but the system recognizes only the 512MB RAM. I've tried...
Check that your memory is supported, according to Biostar documentation for your motherboard:
Single Channel Mode DDR2 Memory
Registered DIMM and ECC DIMM is not supported
Re-check the memory module's specifications.
Nov 03, 2009 | EliteGroup P4M800-M7 Motherboard
Need to know mem spd...333...400 etc to add cards
Memory Installed 512 MB (2 x 256) Maximum allowed 4 GB* (4 x 1GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
Thats the sticks you need
Good luck
Feb 26, 2009 | HP Compaq Presario SR1630NX PC Desktop
Want to buy more RAM..
Your dell dimension takes DDR ram. These are the specs:
Supported pin types: 184 pin DIMM (regular desktop DDR ram)
Supported memory types: DDR PC2700 or DDR PC3200
Supported speeds: 333mhz or 400mhz
Supported stick sizes: 128mb, 256mb, 512mb or 1gb.
MAXIMUM MEMORY ALLOWED: 2gb (2 x 1gb sticks)
If you buy two of these you will max out for ram and give you the best performance::
Dec 24, 2008 | Dell Dimension 3000 PC Desktop
Intel D845GBV Motherboard RAM
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
System Memory Features
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Unbuffered non-ECC DIMMs only
    Maximum total system memory: 2 GB; minimum total system memory: 64 MB
    Serial Presence Detect (SPD) DIMMs only
    Suspend to RAM
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
Feb 05, 2008 | Dell (E210882) Motherboard
RAM has to be
Four 184-pin DDR DIMM sockets
Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
Maximum HP/Compaq approved memory module is 1 GB
Maximum HP/Compaq approved memory is 4 GB
It has to be the same.
• If you are replacing a memory module, put the
new memory module in the same memory slot
from which the old memory was removed.
• If you are adding a memory module, install the
new module into the socket nearest the
preinstalled module, and install additional
modules in the next available sockets
Jan 14, 2008 | Computers & Internet
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
Asrock M266A Motherboard Logo
101 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
