I recently moved to a new city. When my washer was hooked up, it wouldn't not work. It fills up with water and stops. Won't do anything else. Need help
  • 481 Answers
  • check the wires that connect to the motor, they may have worked loose during the move.
  • also check the lid switch and make sure it is clicking when you open and close the lid.
Posted on Jun 29, 2008
I have a 2000 Holiday Aluma Lite Travel Trailer. Having difficulty filling the water tank. There appears to be two places to hook up the hose to fill the tank. Which intake do I hook the hose up to?
There must be a water shut off valve between the tank and the water pump. One of those hook ups will be for city water that goes direct to your tap and the other inlet is to fill the on board tank. Again check for shut off valves.
Jun 12, 2017 | RVs
I have a whirlpool ultimate care II washer. It stopped in the middle of a load, full of water, and now it won't do anything. It won't drain, fill, move, or make any noises.
You will need to check the capacitor on the machine. It can be tested with a capacitance meter the easiest. It can be tested with a resistance meter, but this will tell you if the capacitor is shorted or open. It will not tell you the capacitive value if the component has drifted out of tolerance. You put the meter across the terminals and watch the display for counting up to infinity. This will occur quickly and disappear very quickly. Now reverse the leads on the terminals, (reverse the polarity). The same thing should happen, but a bit more pronounced. It will once again rise very quickly and go to an infinite reading. This tells you that the capacitor isn't shorted or open internally. Here is the capacitor to order if you should find it bad.
Nov 28, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Roper ras7133kq1, top load washer. About 3 months ago I replaced the lid switch because it wouldn't drain or spin. Now it will ONLY spin, it won't fill with water or agitate, the only way...
If it won't fill you will need to replace the "water inlet valve" on the back of the unit. The unit will only agitate if it gets the signal from the water level pressure switch.
Here is the valve to order.
Nov 22, 2012 | Washing Machines
We put a heavy blanket in the washer and the load stopped suddenly with a washer full of water. It wouldn't spin or empty and made a weak sound but nothing worked. We had to manually empty the water....
Usually that means the drive belt is loose and slipping. You should be able to tighten or replace the belt.
To test the belt you have to remove the washer back.
Jul 29, 2011 | Kenmore Washing Machines
Top loading GE color profile washer (wpse4200a) won't fill
You may have a water supply problem. There is a mesh screen in the hoses where they hook to the washer. Make sure they aren't clogged up
Sep 19, 2009 | Washing Machines
Washer fills with water then stops
2 things make sure the washer is balanced. and make sure theres nothing was stuff in the bottom of the washer when you were moving
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
WASHER FILLED WITH WATER AND STOPPED WORKING COMPLETELY
if you hear a motot running the coupling between the motor and transmission has disinagrated.
Dec 26, 2008 | Maytag MAT12CS Top Load Washer
Wash cycle will not start
you may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
Apr 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
