Panasonic Plasma TH-42PX600U
The cable company screwed up their CableCard support. In order to fix it, we need to do a reset on the TV. When we try this, it prompts for a password. I'm about 99% that I never set a password. I contacted Panasonic to see if there was a way to force a reset of the password. No luck. However, they did suggest two ways to force a reset on the TV itself. 1) Hold volume-down on the TV and OK the remote. 2) Pull the power cord for 2-3 minutes. The first didn't work. The second did put us into first-time-setup mode, but the card was still not recognized (so I'm not sure if this method didn't work or if it did and we have a separate cable company problem).
My question is: Does anyone know a way to force a password reset or a sure-fire way to force a TV reset?
Thanks for any help.
  • ts_62 Jun 30, 2008
    There's no cable box involved. We're using a CableCard. The initial cause of the problem was a system upgrade by the cable company, but that should have been fixable by reinstalling the card. It's possible the card is bad, but we can't tell because the TV doesn't seem to want to reset. Thus my question on the ability to force either a password reset or TV reset.
    Genius:
  • Televison & ... Master
  • 1,689 Answers
Disconnect the cable box, and put the standard cable feed on to the TV set. Now see if it works!
Or, with the cable box disconnected, see if the set works with the DVD player.
I strongly believe that the problem is with the cable box, and not with the TV set!!!
Jerry G.
Posted on Jun 28, 2008
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
When turn it onit has a snow screen and nothing works how do i fix it
Check the input signal cables. If found OK; check and replace is tuner.
Jun 30, 2015 | Panasonic TH-42PX600U 42 in. Plasma HDTV
Service menu tv 42px75u
Sounds like an issue with the remote. Try other functions, too. You may need new batteries.
Nov 30, 2013 | Panasonic TH-42PX600U 42 in. Plasma HDTV
I have a TH-42px600u & there is no power going to it, the power cord is working, but the Tv is getting now power. Is there a fuse I should replace or a reset button? Help PLXX!
Of Course there is a fuse at its main power regulator board. but, you must have sound knowledge in electronics, to replace it, especially to Plasma displays. If you wish to get more details, check the site linked here. If you have confidence, follow. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 14, 2013 | Panasonic TH-42PX600U 42 in. Plasma HDTV
Panasonic th-42px600u high pitch sound
likely a coil or small transformer in the set is vibrating hard enough to make it squeel, it would have to be located with back off by listening to see where it comes from.
cure would be to replace the entire board it is on or hot glue the part that is causing this to dampen the sound.
If it is coming from the front screen unit that is a more serious issue.
Dec 23, 2012 | Panasonic TH-42PX600U 42 in. Plasma HDTV
I have a Panasonic TH-42PX600U and the RF board displays a red light and the screen says no channel found. Can I change the board myself, does it just snap into place
if you have the right tools then you can do it, make sure unplug the tv unit first while replacing the board. then mark or put a label to the connector that you were disconnect not to interchange that can cause of damage to the other board.
Sep 17, 2012 | Panasonic TH-42PX600U 42 in. Plasma HDTV
CableCard Information
look on back of tv. it should be there. if it's not, then, well, sorry.
Aug 03, 2012 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
I need a manual for the panasonic t.v. th 42px600e
user manuals here http://www2.panasonic.com/consumer-electronics/support/Televisions/VIERA-Plasma-HDTVs/model.TH-42PX600U
direct link to the manuals
  • http://service.us.panasonic.com/OPERMANPDF/TH42PX600U-MULTI.PDF
  • http://service.us.panasonic.com/OPERMANPDF/TH42PX600U.PDF
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 03, 2010 | Panasonic TH-42PX600E 42 in. Plasma...
Does model th-c42hd18 require only a panasocin wall mount bracket. Seems others do not work
I am not familar with your exact model but my Panasonic TH-42PX600U 42 in. Plasma uses a generic brand wall mount. The first mount I bought would not fit so I returned it and bought a different brand which worked well. Start shopping your local stores (even walmart has a couple of different types to choose from), carefully open the packaging in case you need to return it and see if it will fit the mounting holes on the back of your TV. If it fits on the back of the TV then you should be good to go.
Jan 11, 2009 | Panasonic TH-42PX600U 42 in. Plasma HDTV
Televison & Video Logo
375 people viewed this question
Top Televison & Video Experts
