Question about Rowenta DG-980 Iron
Stean escaping around cap
Iron is new, used once. I have taken the cap off and put it back 6 times and still will not work. I have the older model for 3 years and no problems.
  • Roland Wong
    Roland Wong May 11, 2010
    Please check the damaged threads and sealing surfaces of the all metal brass tank for cracks or evidence of water leaks. Also, the metal cap has a neoprene gasket seal that should inside it, that should have a groove indicating it is contacting the threaded nipple. You may also want to compare it with the older model, swapping them and checking if the problem stays (indicating tank problem) or transfers to the properly working one (indicating bad cap or seal).
    Scholar:
  • 70 Answers
If you need a new sealing plug or parts, since I am in California, I use the website below for DG-980 parts:
California Electric Service
(925) 827-1011
1170-G Burnett Avenue
Concord, CA 94520
http://www.californiaelectricservice.com/
Hope this helps, good luck and keep in touch.
Posted on Jul 11, 2008
Steam escaping?
do the following step:
1) distilled water and softened produce leak , change the water
2)put water until the LEVEL
3)give time enough thermostat for heating. if you use before to HEat enough produce leak.
4)switch dial off to test the water stop leaking,when the steam setting is NOT working.
5) shake back and forth for a few time, to turn on back it is auto-off function.Can be leak when is auto-off mode
God bless you
Jul 14, 2012 | Irons
My stean iron leaks lot of water when steaming what can I do?
try putting iron on a higher temperature this is the way my steam iron work
May 16, 2012 | Tefal Irons
Bosh sensixx B25L iron spraying brown water
I have a bosch sensixx b25l and it has started spraying brown water all over the clothes how do I descale it please
Feb 22, 2010 | Bosch Irons
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Jul 22, 2009 | Rowenta Irons
Rowenta Professional Iron - steam button suddenly stopped working
Have you tried descaling it? It may well be blocked up with limescale. Personally I only ever buy cheap irons and bin them when they go wrong! As you say-they are generally too expensive to repair.
Jun 11, 2009 | Rowenta Professional DX8900 Iron
Broun iron (model SI6285) quit working
Small appliances nowadays aren't really designed to be taken apart. Most likely there wont be replacement parts, you are probably better off just buying a new one.
Jun 06, 2009 | Braun SI6285 Iron
My grandson knocked my Rowena Iron model DE-87.1b
go to the store get a 2 part epoxy glue follow the directions and mix the glue put it on both the knob and the part the knob goes on wait untill the glue gets tacky then put the knob back on wait 24 hrs. before you use the iron so that the glue can set
Apr 24, 2009 | Rowenta Irons
Rowenta steam generator
Maybe the cap is coated with mineral deposits. Do you use ONLY DISTILLED WATER in the iron? If not, minerals from the water could be the cause. Try pouring some CLR or a similar product over the cap and see if that frees it up . If it does, pour some CLR into the iron's tank, and set it to the highest temperature setting. Run the iron over an old towel to help clean the steam vents. Then fill the tank with DISTILLED WATER and do the same proceedure two more times using DISTILLED WATER ONLY to flush out any remining CLR.
Aug 27, 2008 | Rowenta Steam Generator DG050 Iron
Steam escaping around the cap
If new parts are needed, and I am in California, I use the website below for DG-980 parts:
(925) 827-1011
Concord, CA 94520
Jun 28, 2008 | Rowenta DG-980 Iron
Rowenta DG-980 Iron Logo
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
