Question about Whirlpool GHW9400 Duet Washer
Whirlpool duet washer model GHW9400PWO
Need to replace the control panel cover. Can remove left side that has torx screw, middle that has snaps but on right side cant seem to find release.
Removing the Washer Top
Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
Removing the Console from the Cabinet
Disconnect the Touch Pad/LED Assembly ribbon connector from the left side of the Central Control Unit and release it from the wiring harness brackets on the right side of the washer top
Remove the detergent dispenser drawer by pressing down on the release tab at the back of the drawer and pulling it completely out of the washer.
Once the drawer is removed, remove the screw in the recessed hole next to the drawer opening. Release the tab securing the right side of the console to the washer
Open the washer door and place a flat-bladed screwdriver into the slot in the bottom center of the console. Push the console up to release center console tab. Be sure the ribbon cable clears the cabinet frame.
Removing the Touch Pad/LED Assembly from the Console
The Touch Pad/LED Assembly is removed as a single unit and contains the Push Buttons, LEDs, cable, etc. The buttons can be replaced separately
Posted on Oct 05, 2008
What do you use to remove the screws from the front panel of the Whirlpool Duet to access the drain pump? Does not take flat nor Philips screwdriver and pliers won't work.
Hello, welcome to FixYa.
To remove the access panel you will need to remove three #20 torx head screws. To do so you will need a #20 torx bit or #20 torx screwdriver.
Good Luck and thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Aug 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool top loading washer approx 5 years old....it seems that the motor coupling is bad and I would like to tackle this myself. I have seen tutorials where it seems easy to get the control...
SOMETIMES THEY HIDE THE CORNER BACKSPLASH SCREWS ON THE BACK ATB 45 DEGREE ANGLE USUALLY PHILLIPS HEAD SCREWS..... THEN BACKSPLASH WILL FLIP UP UNPLU MOLED POWER CORD AND ... LID SWITCH HARNESS AND TWO CABINET CLIPS THEN YOU WILL NEED A 1/4 NUT DRIVER A HAMMER AND A SOCKET THAT FITS INSIDE DEMISIONS OF COUPLER ...... REMOPVE CABINET AND SET OUT OF WAY....
DEAD CENTER IN FRONT OF WASHER IS A GREY PLASTIC ,OR WITE PUMP REMOVE UPPER AND LOWER SNAP CLIOPS AND SLIDE PUMP TO THE LEFT THEN YOU HAVE THE MOTOOR TO MORE LARGE CABINET CLIPS WITH TO 1/4 SCREWS REMOVE BOTH AN D PRY UPWARD TO REMOVE MOTOR CLIPS AND YOUR COUPLING WILL BE ON BACKSIDE OF MOTOPR PRY OFF OLD COUPLING OFF MOTOR AND TRANS SIDE ALING D SHAFT ON COUPLING TO MOTOR INSTALL SOCHET IN MIDDLE TAP WITH HAMMER TIKLL SHAFT IS EVEN WITH NEW COUPLINF REPAT FOR TRANS SIDE INSTALL NEW RUBBER BUSHING AND REASSYMBLE.....
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Wash load stops with a few minutes left and unit alarms f02, don't see any visable drain problems
Hi, pop off the front cover (3 Torx screws on the bottom lip) After removing the cover you will see a white plastic unit with a screw on cover on the front. Unscrew the cover (no tools needed). Pull the cover off then remove the strainer. It will have gray gook on it plus God knows what else. Clean the strainer in the sink replace screw the cover back on and your in business.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F06 code on my Duet model
first before replacing any parts,check the wire harness from the motor tachometer on the end of the motor and the e.c.u. electronic control unit,they get small amounts of corrosion and can't pass r.p.m. signals to the control board,you may need to remove and re insert themk to clean the contacts,then if this doesn't help,then replace the hall sensor/tachometer on the motor,and finally the e.c.u. in the very end
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i remove the mcu in my whirlpool duet
you will need to remove the upper rear cover behind the control panel on the back side of the machine and remove the four screws securing it,then remove the wiring harness connecting it to the machine electrics
Jan 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water is leaking out of the machine Im not quite sure where from.I guess pouring out would describe it better .It`s not coming from the door.
leaks are usually from valve /dispenser area on top left or from door boot. to check valves open top cover by removing 2 or 3 torx/ 1/4' screws at rear and slide back. check underside of dispenser for cracks, check rubber hose connecting valves to dispenser.
to open front and check around boot, remove top cover, remove screws beside dispenser opening (remove drawer) snap control console off starting at dispenser side. On older non teardrop front disconnect and remove interface cables from ccu at rear (ribbon cable in clips on right side. On new teardrop models remove teardrop by unsnapping at top then work down carefully, then unclip console starting at left, disco cables at right side of interface. remove lower kick panel with 3 screws on bottom. then remove 2 front panel screws. remove 2 door lock asm screws and spring clip around boot, then 2 front panel top screws. panel comes right off, carefull of boot. door lock stays behind.
Apr 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet
you can remove the lower access panel of unit ( 3 screws across the front bottom of unit), behond there directly in the middle of machine yuoll see large plastic turn screw. that s teh pump housing "filter cleanout". unscreww and clear all debris. be aware however if theres water in machine it will come out on you when you release teh turnscrew
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9400PWO, Front Panel comes off
There are no fasteners that I know of. I've worked on this model numerous times and have never seen any. There should be screws holding the front panel in place. Remove the lower panel under the door by removing the screws under the bottom edge. HINT: Placing a block of wood under the bottom of the frame to elevate the front feet of the washer off the floor will make it easier to access the screws. The washer is heavy so it may take two people to do this. DO NOT push on the door or the control panel. Use the facing of the washer front panel for leverage. With the screws removed, the panel will drop down, then come off. There should be a mounting screws for the front panel on each side of the washer. Make sure the screws are present and that they are tight. You may just have a screw loose (no pun intended). I hope you find this information helpful. Let me know if you need further assistance.
Sep 26, 2008 | Whirlpool GHW9400 Duet Washer
Take apart washer
just remove back ...don't remember seeing broken belt on duet except the sport version..as far as control panel remove top a couple of screws top front and snaps in at bottom but IF AIN'T BROKE DON'T FIX IT
Aug 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
565 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
