Question about Maytag Performa PAV2200
Dishwasher problem The cycle seem to run, but the soap does not disolve. I use the packet type. Any ideas? Amy
  • 639 Answers
Go to liquid or powder.
Kirkland brand at Costco is the best for the money!
Posted on Aug 24, 2008
The soap tray does not open during the wash cycle
Latch solinoid problem. Chance of relay and other circuit fault.
enjoy using the machine by palcing the soap in a small plate in the rack. The sparay arm will disolve it during the job. Economical solution !!!
Apr 01, 2010 | Miele G892SC SS Dishwasher
My 13 year old Frigidair dishwasher (model FDB221RFR2) is not disolving the soap tab that drops in during the later cycles. We sometimes find the soap sitting on dishes or on the bottom. It appears that...
could be a couple of things. water valve semi clogged. circulation pump not working to it full capacity.also the water line not completely opened.a line
Feb 25, 2010 | Dishwashers
Soap does not disolve and residue left on all
The problem is hard water. Go to They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 17, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kemmore dishwasher not disolving detergent packet
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
First Choice Appliance
Jul 09, 2009 | Kenmore 15899 Built-in Dishwasher
The soap packet doesn't dissolve, it remains intact at the bottom of the machine at the end of the cycle.
don,t use those packets stay with powder or liquid dishwasher soap. the packets need a lot of heat to dissolve,.
May 29, 2009 | GE Nautilus 24" Built-in Dishwasher
Soap not Disolving
possibly the water is not hot enough, it needs to be hooked up to a hot water line ONLY. also check to see what cycle the dishwasher is set at, there are three or four different settings. start off by using the pots and pans cycle because that cycle will delay the wash to superheat the water.
remember hot water only and water should be set at 120 degrees.
good luck to ya
Dec 29, 2008 | Frigidaire 24 in. PLD3465REC Stainless...
Soap packets don't melt/disolve
sounds as if you amy have a problem with the dispensor door not opening correctly perhaps opening at end of cycle when all water is already released.Ive seen that sometimes the "tabs" or "packets of detegent are too tall and interfere with normal opening of the latch mechanism. manufacture would reccommend using powder instead.
Nov 04, 2008 | Dishwashers
Soap door won't open during wash cycle
Jan 17, 2008 | Kenmore 24 in. 16592 Built-in Dishwasher
Washing Machines Logo
74 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
