Question about Onkyo Audio Players & Recorders
Onkyo six CD changer stuck closed, reads "Mechanical Error" in window...Also, new Onkyo tape deck TA-RW255 tape stuck, won't open and won't turn off.
    President:
  • 624 Answers
The Onkyo CD changer has an internal mechanical problem that could be anything from a disc being jammed in the mech, to a bad belt, or a bad IC or supply voltage that goes to the servo circuit. No way to be certain without troubleshooting it. You can open it up and see if a disc is stuck, but unless you have some experience in this sort of thing it is better left to a professional, You can cause more damage than you started with by trying to fix something you don't know that much about.
The tape deck could have any number of problems as well. A bad belt or gear, a defective servo circuit, and the list could go on, but they are all things that also should be checked by a professional.
Most of the time a tape won't eject is form the tape head being engaged and not letting loose of the tape. But since it won't turn off, you have some more serious problems. That is an indication of something not communicating with the microprocessor. It could be a digital transistor, a shorted capacitor, and like before, many other things. Whatever you do, don't force the tape deck open. It will destroy the head assembly and it may even void your warranty (you did say it was new).
You need to find an authorized Onkyo service center near you. Contact Onkyo if you can not find one yourself.
This really is the best action you could take. Onkyo is a very good brand, and in most cases is worth getting repaired. If it were some type of cheap-o brand it wouldn't matter what you did to it because replacing it would always be cheaper than paying for a repair. That is not the case with your equipment.
If I can be of further help, just ask me.
Dave
Posted on Jun 28, 2008
TA-RW255 DUAL CASSETTE DECK
Have you check and make sure that the belts are working well?
Is the pinch roller working (spinning)?
A worn out belt will make the mechanism not to operate properly resulting in shutdown to avoid damage to the tapes.
Apr 11, 2008 | Audio Players & Recorders
Pioneer ct-wm60r reads err, has new belts,
There are sensors in the unit that are false triggering and some mechanical parts that require alignment. It can take two or three hours to put it back right if you are not familiar with that transport.
This is why I tell people to stay away from changers and auto reverse units as sooner or later they will be a real problem for someone to fix.
Dec 20, 2016 | Pioneer Audio Players & Recorders
Where can I find a repair manual to replace belts on my Onkyo Stereo Cassette Tape Deck TA-630d
I have found a service manual for you that can be downloaded free:
http://elektrotanya.com/onkyo_ta-630m-sm-tape-deck.pdf/download.html
After the page is appeared fully, click on this place:
Get Manual
Not logged in
Only 2 downloads
allowed a day
and the downloading will begin.
gylacz
Mar 31, 2011 | Onkyo TA-RW255 Single Cassette Deck
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Dec 27, 2010 | Onkyo Audio Players & Recorders
Gunk fused to record & playback heads of Onkyo cassette deck
The best cleaner for heads is Servisol Video 40. You can get it from Maplin's UK or Amazon.
Mar 19, 2009 | Onkyo TA-RW244 Single Cassette Deck
Cassette tape spins fast
Hi Chris..
It's not worth repairing. I would find something else in good condition
Feb 01, 2009 | Onkyo TA-RW244 Single Cassette Deck
Onkyo TA-2700 - Won't Play Tapes
Open the deck and look for the copper colored leaf switches (above the plastic comb) that get corroded / dirty over the years.. Clean them with deoxide or similar and your are most likely good to go..
Aug 14, 2008 | Audio Players & Recorders
115 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
