I had a backup and restoration done to my computer. upon reinstallation of my magix program I was unable to access my old files. Any suggestions? Dave.
  • 35 Answers
Perhaps access restriction, look at microsoft kb
Posted on Jun 28, 2008
My computer crashed, how do I recover my NTI Backup Now EZ program? My computer can't find the NTI setup.exe.
Many people confuse system back-ups with system restore and/or recovery programs. They are very different. A backup makes a copy of selected (or all) files and stores them to a disc, tape, hard drive, or other device that will allow you to protect your files in the event of data loss. Say you accidentally delete an entire directory instead of a single file. Your backup would allow you to re-load that directory. System restore/recovery files are used in the cases where you either want to reload the computer back to a certain condition (factory restore), or need to completely recover your computer in the event of a crash. These types of files usually need one of two things to work. If the recover/restore software was OEM manufacturer supplied, there may be a BIOS routine that, using a hotkey on boot-up, will allow you to access the recovery/restore file. If it is an aftermarket program like your, recovery/restore files usually need to create a bootable USB or CD/DVD that can be inserted on boot-up, and then the files on that device will perform the recovery/restore. If all you have a a system backup, you may have to reinstall the operating system, drivers, and then the backup software. After that, you can use you backup file to recover your remaining programs/data.
Sep 29, 2015 | NTI Computers & Internet
I do not want to restore a backup, I want to read files from the backup files
Typically back-up files made by back-up programs are encoded, and depending on which back-up software this may or may or may not allow you to access the backed-up files individually. How you access your backed up files will also depend on the back-up software you use.
For HP's back-up utility, "to recover a deleted file, simply use the Restore Wizard" - be careful not to recover the file on top of the current version of that file though.
http://h20331.www2.hp.com/Hpsub/cache/312352-0-0-225-121.html
see also the instructions (manual) for this utility
http://www.hp.com/ctg/Manual/c01824301.pdf
This procedure should work for any back-up software.Copy your back-up. Restore your back-up to a new location. Access the files you want from the restored back-up. Now you have access to the files in the back-up as they were when they were made, while still retaining your back-up and your current files. Be careful not to confuse 'old' for 'new' and 'copy' for 'original'.
25.April.2014
Mar 12, 2014 | SimpleTech 250GB USB2.0 7200 RPM External...
Erdmpg-6.dll access violation error
Getting the erdmpg-6.dll error pretty much indicates there is something wrong with the erdmpg-6.dll file, either it is absent from the computer or is damaged (corrupted), if so, the system will unable to read or access to the file when needed. When you encounter the error, first reboot your computer once, if the error persist, you can try to download the erdmpg-6.dll file from the internet, or get a healthy copy from another computer, and then replace the file in the suitable area in the computer.
Secondly, you can try to reinstall the program/application that trigger the error tofix erdmpg-6.dll error. but remember not to reinstall it until you uninstall the current installed one, to uninstall a program, go to Start > Control Panel, click onAdd/Remove program option and use it to do the removal.
Most of the time, registry problem is responsible to the erdmpg-6.dll error. Windows registry is part of the system, it is much important than any other system components, all the software & hardware data are stored in the registry. The erdmpg-6.dll error usually happen when the Windows registry gone corrupted or the related entries inside is damaged. To test if the registry of your computer is having problems, you can perform the steps below:
If you are experienced enough, you can open the registry editor, find out all the unnecessary or wasted entries inside, and delete them all, then modify the problematic key value to the proper status. Before any modification, we suggest you to backup the registry first to avoid crucial problems caused by mistaken operation.
Step to backup Windows registry
  • First open Registry Editor by clicking Start and go to Run.
  • Type in regedit, and click OK.(fig1)
  • Click on the File menu, select Export.(fig 2.png)
  • In the pop-up window, select the location to store the backup file.
  • In the 'Export Range' section, select All.
  • Type in the backup file name, and click 'Save' button.(fig 3.png)
How to restore the registry
  • Open Registry Editor.
  • Go to File > Import.( fig11.png)
  • Locate the backup file you have already created.
  • Select it and click Open button.
  • Restart the computer after the restore.(fig 12.png)
  • Registry modification is kind of a complicated task for average computer users since there are thousands of registry entries, it is hard to spot out and clean every wasted one, no mention to modify the incorrect entry value, it can be dangerous if the value is modified improperly, your computer may end up crash, even registry backup can't save it. Fortunately you can use registry tool to help you out, simply follow the below three steps, you will be able to fix the registry as well as fix erdmpg-6.dll error automatically:
    Step1: Free download erdmpg-6.dll error fix tool, and then install it in your computer.
    Step2: Click Start Scan Now button to scan over your computer for existing problems and errors.
    Step3: Click Fix All button to completely fix erdmpg-6.dll error.
1_27_2013_10_16_57_am.png1_27_2013_10_17_34_am.png1_27_2013_10_17_51_am.png1_27_2013_10_18_57_am.png1_27_2013_10_19_12_am.png
Jan 27, 2013 | CoolwareMax WebcamMax
I have problem reinstalling magix edit pro 17 because after removing and now reinstalling the problem of...... ENU(USA) 10.0.0.0 "the installation is not possible because the following related...
Maybe a file in the usual program or configuration directory was locked by another program (e.g. antivirus scans) when you were removing the old edition of Magix Edit Pro; that would leave directories like /Programs/Magix and /Data/Programs/Magix and possibly registry entries (call up RegEdit and delete (or export and then delete) the old items pertaining to Magix or EditPro) around blocking 17 from coming in. Just rename those vestigial directories so they won't be in the install's way. Then retry and report...success?
Oct 02, 2011 | Magix MOVIE EDIT PRO 17 HD PLUS
How do I access the hidden partition to reinstall operating system?
Turn on or restart your notebook, then press F11 while your notebook is
starting.
3 Insert the Operating System Recovery CD/DVD when prompted. The System
Recovery program starts.
Click a system recovery option
Full System Restore (Destructive) reformats the hard drive and
restores the system software as it was when you purchased your
notebook. This process deletes your data files.
Full System Restore with Backup (recommended) moves the
contents of the hard drive to the C:\My Backup folder and installs
a new copy of Windows XP. This option saves your existing data
files, but all programs must be reinstalled and the program settings
reconfigured. You need at least 4 GB of hard drive space to use this
restore option.
5 Click Next. The System Restore - Format and Recover dialog box opens.
6 Click Yes. Files are restored to your hard drive. When file recovery has
finished, the System Restore dialog box opens.
7 Click Restart. Your notebook restarts, and Windows finishes its setup and
installation.
Important
After you restore your system, it will
appear with the same files and programs
it had when it shipped from the factory.
You still need to download Windows
updates and antivirus updates to bring
your notebook’s software up to date.
8 Reconnect your Internet cable and all USB peripheral devices. You are
done.
Apr 03, 2010 | Gateway MX6214 Notebook
Can I install movie edit pro 15 plus on multiple computers?
1. CONTRACT PURPOSE MAGIX grants you (the customer) a non-exclusive licence for the enclosed MAGIX product. You are granted the right to use the purchased software as well as the music and video files on a computer (with one CPU or on a multi-processor computer) or in a network under the condition that access is provided on only one network computer. If several network computers have access to the server, then a separate license is needed for each network computer (workstation). MAGIX retains ownership, copyright and other proprietary rights related to the software. You (the customer) acknowledge the licensor's ownership as well as all proprietary rights to the software, music and video files, back up copies and documentation. The buyer of the program is solely responsible for the proper contractual use of the licensed programs.
See the full agreement at
http://www.magix.com/us/links/eula/
Feb 24, 2010 | Magix Movie Edit Pro 15 Plus for PC
Unable to reinstall DVD backups after HP SYSTEM RECOVERY failed
Code "purple" means you and your computer are done. It is an unrecoverable error that means you need a new system. However, I have found a couple of postings that claim to know a fix. I can not verify these methods, I do not own a HP or other type of prefab PC (custom is the only way to go). Anyway, here are the links, good luck.
http://h30434.www3.hp.com/psg/board/message?board.id=HardwareDPC&message.id=6115
http://forums.techguy.org/windows-nt-2000-xp/469752-code-purple-configuration-error-hp.html
http://forums.techguy.org/all-other-software/644163-code-purple-advice.html
May 16, 2009 | HP Computers & Internet
No WindowsXP, corrupt file windows\system32\config\system
Sad to say but alot of the computer manufacturers send Windows install/restore disks that are basically hardwired to the original hardware setup. The only real solution if you cannot install over your old setup would be to purchase the full version of the Windows o/s you want to install. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | EliteGroup ECS C19-A SLI C19XE & MCP51...
File is not accessible. Access is denied message
Hi.
Sorry for the delayed responce. Ok first thing is first. The "files/folder is not accessible" occurs because the program cannot find the files in the place where they should be. for example if you put your socks in a draw and your wife moved it, when you return you wont have axcess to them right :) will basically its the same thing here. What you will need to do is find the default directory of itunes it should be in the Options or tools ir settings menu (I dont use itunes so i am not sure just play around in the program until you find it) once you do you need to search you computer for where the PC Backup put your files ..
click start then search and type the name or piece of the name of a song you know should be there. Once you find it browse to the directory of where the song is located. Click start then my computer then local disk to get to your harddrive. Go to the folder that has the songs and copy them. then paste them into the directory where itunes is looking for them.
Jul 06, 2008 | StompSoft BackUp My PC 2005 (05004) for PC
18 people viewed this question
 Grubhead
Grubhead
