Question about RCA LCDX2722W 27 in. Television
Rca scenium model # L26wd14
I've tried unpluging the t.v for 24 hours an still i see unuseable signal i'm not sure what else to do is there some way of reprograming the t.v it selfe
4 Suggested Answers
SOURCE: "weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Posted on Apr 12, 2007
  • 8457 Answers
SOURCE: 42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Posted on Dec 05, 2009
mpaint
  • 36 Answers
SOURCE: 42 inch rca lcd tv says unusable signal
This is a very common problem with these models.
The problem is very likely a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Posted on Jul 23, 2010
My 61in rca scenium is saying unuseable signal and there is no sound or picture
For whichever input the monitor is currently set to (i.e. Input 1, HDMI 2, etc.) it is telling you that the signal it is receiving is unusable. The question first is the monitor set to the input you truly wish to use?
If it is, then check the cabling between the monitor and the source device (cable/satellite box, game box, etc.) If you believe it the source is working, try swapping the cable or using a different input.
If that fails, try hooking up the source to another monitor and seeing if it works there. If you have a long cable run, try higher quality cables, the video signal can degrade over long runs (> 25').
It sounds like the monitor is receive *a* signal, just not one with enough data to be useable. Probably a bad cable.
May 06, 2011 | RCA Televison & Video
No picture/sound
YOU HAVE AN INTERNAL TUNER FAILURE IT NEEDS TO BE REPLACED
CONTACT RCA FOR REPLACEMENT PARTS OR INFORMATION
here are some contact information for rca
http://www.rca.com/content/viewdetail/1,2811,EI45168,00.html
Questions about operating or setting up your
HDTV: Call us toll free at 1-866-SCENIUM
(1-866-723-6486), or send us an email.
Quality comments? Call us toll free at
1-866-SCENIUM.
Jan 06, 2008 | Televison & Video
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
Rca scenium 52" has light bar area down each side
I take it that you have watched many hours of 4x3 video on this 16x9 TV . What you see is evidence of screen burn, like they used to warn about with the old "pong" type games with stationary objects. The 4x3 pattern is burned into the phosphor in the projection tubes. the area of the burned pattern is not as efficient as the unused areas that make up the 16x9. If you watch enough 16x9 it may even out somewhat, but will never be perfect. Replacing the tubes will fix it, but they're pricey, and you may be subject to it happening again, depending on your viewing habits.
May 25, 2009 | RCA Scenium M50WH187 50" HDTV
RCA Scenium
What does the picture look like when it is on?
Dec 03, 2008 | RCA Scenium D40W20 40" Rear Projection...
61" RCA Projection TV, no picture, "unusable signal" message
Read the suggestion of unplugging the TV for at least 4 hours to re-set to factory specs and that took care of it!
Apr 03, 2008 | RCA HD61LPW165 61" Projection HDTV
Unusable video signal
e-mail me or call me 520-248-4242 any time
Dec 11, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Unusable signal
Could be a bad buffer/amp or bad tuner, depending on source selected....accordianman
Dec 08, 2007 | RCA Scenium D40W20 40" Rear Projection...
Jan 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA LCDX2722W 27 in. Television Logo
182 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
