Roper RAB2121KW fills with water but doesnot work
  • drive2 Jun 28, 2008
    It doesnt do anything except continue filling with water if i move it near spin cycle. water doesnt drain. made noise for a little while on previous load before quitting.
  • Mike Durland
    Mike Durland May 11, 2010
    does it make any noise or does it just sit there?
     will the water eventually drain out or anything?
  • 481 Answers
  • it sounds like it could be a bad motor.
  • the motor runs everything but the water filling.
  •  if it didn't make any noise b4 quitting then it might be a timer problem,
  • either way it is an expensive problem $100+ just for the parts.
Posted on Jun 28, 2008
Washing maching not filling with water
The problem is most likely the water fill sensor switch. If it is telling the machine that it is full, it will go right to agitate.
Apr 25, 2009 | Roper RAB2121KW Top Load Washer
Top Load Roper Washer does not agitate during wash/rinse cycle
You may need to replace agitator dogs located inside the agitator or the drive coupler located above the motor. It dependis on which model you have.
Jan 02, 2009 | Roper RAB2121KW Top Load Washer
Roper top load washer
jumped across the lid switch and everything worked so replaced switch
Aug 12, 2008 | Roper RAB2121KW Top Load Washer
Roper washer wont Agitate
you have a bad watwer inlet valve but the agit. has nothing to do with the water unless you are not getting enough into the machine to start the agit cycle
Jul 29, 2008 | Roper RAB2121KW Top Load Washer
Washer will not fill all the way.
you may have to adjust/replace the water level switch. it is located behind the control panel. the water level knob is attached to it. it does have a screw adjustment.
May 15, 2008 | Roper RAB2121KW Top Load Washer
Washer will not fill with water
We have not heard back on this in a about a week. I'm presuming it's been repaired?
May 04, 2008 | Roper RAB2121KW Top Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Washer takes forever to fill
sediment gets clogged in the valve that cant be cleaned if you replaced the water valve it will solve the problem
Nov 25, 2007 | Roper RAB2121KW Top Load Washer
My Roper top loading washing won't stop filling.
It's not necessarily the angle of your drain hose. When it drains as you fill it, it's called a siphon condition. Pull the excess hose out of the stand pipe (drain). Only about 6" should remain inside the pipe. Tie it down with a plastic tie to one of your fill hoses to prevent water pressure from pushing it back out. This should solve your problem.
Nov 10, 2007 | Roper RAB2121KW Top Load Washer
Roper rab2121kw top load washer
By the sound of it, it sounds like you have somethng stuck in your pump stopping the motor. Start with this first. Remove the cabinet and the pump sits right in front, two clips and two clamps and it pulls right off. I will attach some photos to guide you. In the case that you need a new pump the part number is 3363394. Easy job...Catriver..post back
Oct 23, 2006 | Roper RAB2121KW Top Load Washer
Open Questions:
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
