You have posted the problem under Air-Conditioners category which deals with home/office airconditioners.
Kindly submit the question under 2004 Ford Explorer section on the website by clicking this link so that the best car experts can view and post a solution to the problem.
On the page which opens, type the question in the "Ask an Expert" box. Then, click on "Ask a Question" button.
Thanks for using FixYa.
Hello auntdae.... when the fan works and cold air comes out begin by checking the thermostat. Chances are that the thermostat is stuck and not allowing any hot water from the engine to heat the interior of the vehicle.
The good news is this is an inexpensive fix, the part is usually in the $5.00 range. If you are somewhat handy, you can change it yourself. It requires removing two bolts, scraping off the old gasket and then installing a new gasket and thermostat. Joe
But what makes the clicking noise a friend said it may be the air blend door actuator
