WE WOKE UP ABOUT A MONTH AGO AFTER A STORM AND OUR OLDER SYLVANIA TV HAD ONLY THIN COLORED LINE AND BLACK SCREEN FROM WHAT I AM READING IT LOOKS LIKE IT COULD BE VERTICAL SWEEP THE SOUND IS FINE ON ONE LOCAL AND MUFFLED ON THE OTHERS
  • 8,617 Answers
Try replaceing the vertical output IC, or it may just need to be resolderd.
Posted on Jun 28, 2008
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Sony wega kde-61xbr950
Can be a problem with a misplaced connection, more likely the Ysus card to be replaced.
Aug 30, 2008 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
Tip
Hi. I just got my samsung syncmaster 920nw less than 6 months ago, and now i...
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
on Jan 03, 2009 | Sony SDM-HS73P 17" LCD Monitor
Thin vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma display & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Samsung Televison & Video
RCA TV older big back 36" went out during power outage storm, back on with good volume but pictur only a thin line in middle of screen across
People are giving away their older TV's as they upgrade to new wide flat-screens nowadays. That makes your TV not worth fixing. Keep checking Craigslist and your local thrift stores for one that's cheap or being given away.
Jan 03, 2015 | Televison & Video
How to factory reset with only remote, while screen remains black w/ 5 thin horizontal colored lines streaking. Why is screen black?
Without a proper screen, you can't do a factory reset to this set. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 07, 2014 | Samsung PN42B450 Plasma TV
My t.v. is an sylvania and the screen is all black with a white line going across the screen. It only shows images where the white line is and the white line is very thin. how can I fix this problem or...
Sinegalnatal -
Sorry to be the bearer of bad news, but that sounds like your TV is broken. There's very little chance that you'll be able to fix it yourself, as modern televisions are incredibly complicated and dangerous to work in without training. I'd suggest sending it in for service if it's still under warranty. If not, you could look in to a local TV repair place.
Mar 03, 2011 | Sylvania Televison & Video
Black screen ecept for thin white line around all four side. Channel buton changes colors in various section of screen. On/ off button does not work
I found the solution on mine. To restate, I just saw a thin white border around a black screen. Pressing the channel up or down buttons changed the screen, in some kind of test mode to shades of gray, and red, green, and blue. I started finding a solution when I noticed when on one of the color screens, that the volume up or down buttons brought up a new menu for color intensity. Finally, I got back to the thin white border screen and pressed the arrow keys in the top half of the remote. Finally a TV screen and I pressed the enter key! Voila!
Mar 14, 2010 | Sylvania LC320SLX 32 in. LCD TV
Flicker-Blinking on picture
Too late now but I hope you had it serviced while it was still on parts warranty. With a couple of exceptions, service on those is by major pcb replacement.
Jun 04, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
