Question about HP DesignJet 5500PS InkJet Printer
HP 5500 Plotter
Am getting error 0P00100000000C0 in a printer came for servcie. Please let me know the solution. Thanks in advance.
Sorry... the error starts with OB and not OP as mentioned in my previous request. I got this solved by a technician from a local company. He refixed the print head cleaner assembly and the problem got solved.
Best Regards
Austin
Posted on Jun 30, 2008
Hp 5500 system error 0b0005 00000012
hi.I dont know very well english..i am sorry i have a hp 5500ps plotter.there is a mistake while %5(at the beginning)error code:b0005_00000012 i think there is a error aps system.But i cant do it.Sometimes it is working (fixed)itself
Oct 22, 2013 | HP Office Equipment & Supplies
Hi, I am using an HP Designjet 4520ps plotter and am getting error 84.16:01 - Possible paper jam. There is no jam, it occurs somewhere in the middle of a print job and renders the job a waste. Any...
84.16:01 is a BT arm failure.
In the diagnostics submenu, go to 2.2 BT Arm test. Press ENTER.
If you have a failure, The front panel will display System Error Code 01.0:10.
At this point call HP if you still have a warranty. Otherwise, call a trained DesignJet tech
Jun 13, 2011 | HP DesignJet 4520PS InkJet Plotter Printer
How can i install hp designjet 5500 PS on my com puter using network cable? My plotter (hp designjet 5500) do not have USB port instead it has netwok port from which one can install via the local network...
You are doing some mistake.
All peripherals will attach directly to the main server or main system.
Then from the main system you attach the network switch and share the peripherals with other
system.
you connect the printer, plotter, scanner etc to your computer directly through the aproprite cable /
port.
Apr 15, 2011 | HP DesignJet 5500PS InkJet Printer
I have problem with my 5500 hp: check printhead path 2
The most common cause of the Check Print Head Path Error 2 is a worn out carriage belt. Open the top cover and locate the carriage belt. It is the long thin belt that extends the full length of the plotter. Use a light and look under the belt for debris that looks like pencil erasure crumbs. If the crumbs are there, the belt is disintegrating and needs to be replaced. See: http://www.lpscomputer.com/c-732-designjet-5000-5500-belt.aspx
Dec 01, 2010 | HP Designjet 5500 (42 in.) InkJet Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
I don't know where to buy carriage belt
http://www.computercare.cc/osc/catalog/plotter/size.html
check this link out it sould give u your solution. Please get the size etc correct of the belt and iit should be really easy to find
Jul 05, 2009 | HP Designjet 5500PS 42 Printer Open Box
57.4K error message
Unit has a hardware problem:
HP COLOR 4600, 5500 ERROR 57.4
• Replace fan motor (FM2) formatter fan
• Replace DC controller board
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Office Equipment & Supplies
HP DesignJet 5500PS InkJet Printer Logo
435 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
