Question about Electrolux Refrigerators
Looking for a frs22zrf service manual (frigidaire/electrolux). fridge is still running but is not staying cold. Freezer seems ok, but is not as cold as it should be. Side by side unit. Would like to try to repair myself, but will need a service manual. any available for download?
  • flyersgirl Jun 28, 2008
    Thanks for your help!
    Still looking for the service repair manual if anyone can direct me to it...thanks again.
    flyersgirl
Hi there!
You should be able to identify various parts Here
It sounds like a problem with defrost timer control, but may also be the control board for the thermostats.
Just click the link , put in Electrolux, fridges, then electronic parts in the box at the bottom.
(shop around before you buy, and try removing/ testing items before purchase)
Posted on Jun 28, 2008
Electrolux door alarm Won't stop. We open door to turn off alarm. Temp seems right but slight condensation at the very top of the fridge. Need to at least disable alarm until I can get a repair.
Check the back wall of the freezer, I would suspect the beginnings of or a full-on defrost failure... If there is frost on the back wall of the freezer it means the evaporator is blocked, disallowing airflow to the fridge compartment... Electrolux Refrigerator Defrost Thermostat 216731001 . If there is no blockage, but temps are still not cold enough, your Frigidaire may be leaking refrigerant...
Jul 03, 2016 | Electrolux ICON Professional E32AR75JPS...
Frc150ff fridge is too cold
You know that the lowest setting is the coldest .
Set it to 35 refrigerator, 6 degree freezer and see what haopen
May 27, 2017 | Frigidaire FRC150FFS
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Frigidaire FRS22ZRF side by side. Freezer works but the Frig isn't cooling. Anyone know what the problem could be?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 02, 2011 | Frigidaire FSC23F7D Side by Side...
Electrolux ER 7626 Fridge not cooling
On these units there is a defrost heater which comes on after about 12/14 hours running time depending on usage.It would cut in for about 15 mins just to get rid of ice accumulated around the Evaporator.This heater or the timer has failed and ice has got between the duct. supplying cold air to the fridge unit.The best thing to do is to defrost unit for 24 hours and then try it and see if you can feel cold air coming up into the fridge.The repair for this is not that successful and you would be better off defrosting unit like a normal fridge/freezer.
Hope this was a help.
May 12, 2010 | Electrolux ER7626B Bottom Freezer...
Not cold enough all of the sudden
My refrigerator is running but not cool,the freezer side is about like the fridge side!
Dec 16, 2009 | Frigidaire Refrigerators
The refrigerator is not getting or staying cold enough. the freezer seems to working ok
Check the vent at the top of the shared refrigerator wall for cold air from the freezer. If not, then you can either replace the motorized flap inside the vent or prop the flap open with a stick or something. The manual solution won't harm anything. The motorized flap is an over-engineered solution designed to create service calls. :<)
May 21, 2009 | Frigidaire FRS3R5EMB Side by Side...
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
Refrigerators Logo
821 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
