Question about Motorola Mobility RAZR V3xx Cellular Phone
TAKING THE CELL APART
I AM TRYING TO TAKE THE CELL APART TO CLEAN IT.
2 SCREWS WAS NOT A PROBLEM BUT NOW IT IS NOT FALLING APART AND I DO NOT WANT TO BRAKE IT...
ANY ADVICE HOW TO DISCONNECT THE TOP PART?
PLEASE LET ME KNO IF YOU WOULD.
THANKS
  • 43 Answers
Http://modmymoto.com/wiki/index.php/Razr_v3_Taking_it_Apart"
here is a website go here and you will have your answer,
Posted on Jul 09, 2008
How do I clean or fix sticky keys (keys that take a lot of pressure to depress).
Most keyboards can be taken apart easily and cleaned with alcohol. remove the screws from rear of keyboard and it will come apart being careful with the keys not falling all over. if its a laptop they are difficult to clean because you cant take the board apart. you can remove keys and clean with Q-tip.
Feb 11, 2016 | Apple Usb White Keyboard A1048 - Spanish
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
Blueaire 501 dust caked up on wires and fan,how do you take it apart to clean it?
Hi, I have had the same problem and have figured out how to open it.
To open your blueair air purifier, follow the steps below;
1. Get a phillips head screwdriver,
2. Open the unit and remove the air filters.
3. Use the phillips head screwdriver to remove the screws that you can see.
4. After taking out the screws, remove the "galvanizedSwedish steel housing"
(cream coloured sides) of the purifier by lifting it upwards (i.e. from bottom to top of unit).
4. You will now have access to the interior of the purifier.
5. You can now take out the fan and clean it, or what ever part you are trying to clean. I used a Dyson HEPA vacuum cleaner.
6. To reassemble, reverse the instructions above to reassemble the purifier.
Feb 28, 2011 | Blueair 501 Air Purifier
Taking apart Samsung Propel A767
Most cell phones also have little plastic tabs holding them inside besides the screws,i have found that if you look closely ,you'll see some sort of a little slot or opening that you can slide a thin small flat tip screw driver in, Carefully work the screw driver around and the plastic tabs will open.
May 15, 2010 | Cell Phones
Replace the rear right turn signal bulb
There should be two more screws inside the car behind the carpet lining
Sep 17, 2009 | 2004 Chevrolet Malibu
I need to take apart my Kenmore Progressive Bagless Upright with Inteli-Clean System
What problem are you trying to fix? The is no belt so you don't need to remove the bottom plate. If you are trying to remove the main hose, remove 4 screws on the back and remove the plate. There are 2 more screws under that.
Jul 29, 2009 | Kenmore Progressive Bagless Upright with...
T459 screen
Taking it apart isn't that hard, as long as you have a very tiny philips screwdriver. There is 12 screws that you will need to unscrew. The 6 under the battery cover, 2 larger black ones on the hardware, and after you unstick the camera button and the volume button, you can remove the hardware and unscrew the screws that keep the screen cover on. the screen pops out and there you go. you'll also need a small flathead to pop the covers off.
Jun 14, 2009 | Samsung Gravity SGH-T459 Cell Phone
Glass door force4@optonline.net
First remove the door. (on this model I think you open the door part way and pull up to remove it from the hinge) Set the door so that the handle and glass are facing down. Remove the four screws from the bottom and two screws from the top the whole door should just pull apart after that.
NOTE: Make sure you look at where all the trim and stuff is sitting before taking it apart.
Good Luck
Nov 03, 2008 | Frigidaire FGF337EC Stainless Steel Gas...
Dyson dc07
You can take the clear part off pretty easily, but the upper cylcone section is held on by three star screws on the upper -handle end. After taking those off, the handle comes off and it has a long stick that runs down the center of the cylinder. There are now 8 cyclones facing you. Clean them however you want, but I couldn't get it broken down any further. There are three more star head screws down the center, but after taking them out, I couldn't get the purple upper piece apart from the lower, grey piece. So, I just kept it all dry, pounded on it with a rubber hammer to break the crust off everything, ran a screw driver into each of the cylclones to clear them, and put it back together. Make sure you put your hand down at the bottom when you're trying to line up that stick to put the handle portion back on the whole assembly. If it doesn't make it back in it's little home, it won't empty correctly.
I hope this helps.
Joe
Apr 13, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How can I take apart my Razer v3i
http://www.celtnet.org.uk/mobile-phone/disassemble-motorola-v3-2.html
this should help you out, step by step photo tutorial on taking apart the v3 razr
Nov 25, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3xx Cellular Phone Logo
56 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
