The batteries been replaced in the remote- the LED screen indicates that there is power to the remote for a few seconds but then goes blank and the remote will not turn on the split system airconditioning. Have tried the reset button on the remote nothing changes. Do we need a new remote? Thanks for your help.
Thanks for your suggestion. Will try new set of batteries but probably time for a new remote.Thanks for your suggestion. Will try new set of batteries but probably time for a new remote.
You can't post conmments that contain an email address.
If you turn the monitor off then about 1020 sec turn it back on and have
a picture for five sec again it sound like the power supply in the
monitor. but if that did not solve the problem, the
picture board on your monitor is bad, since it goes off after few
seconds and the power led or button is on, it means the
board of your monitor has developed fault and will need to be replace.
I
advice you replace the picture board on the screen of your monitor to
solve the problem of the blank screen.
I
Is it the screen that goes blank or the power of the monitor? is the power led button on?
If the power led button is on, and it is the screen that goes off, this indicates that the picture board of your monitor is malfunctioning and will need to be replaced.
But if it is that everything goes off, it means the inverter is bad and will need to be replaced.
For the parts, yes, Being HP is even advantage, because virtually,most service centers do have the parts
Just walk to any hp service or any service center within your vicinity to get them.
Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds.
After a few seconds have elapsed, plug the cord back into the wall
outlet.
Turn
the power of the Wii console ON. When you see the Health and Safety
screen, open the small flap on the front of the Wii console to find a
red button labeled "SYNC." Press and hold the SYNC Button down for 15
seconds. This will clear all the syncs on the Wii, allowing you to get
a clean start to begin the process described below.
After holding the SYNC Button on the Wii console down for at
least 15 seconds, you can now "re-sync" your Wii Remotes:
With
the first Wii Remote you wish to sync, remove the battery cover on the
back of the Wii Remote to find a small red button just below the
batteries.
Press and release the small red button just below the batteries on
the Wii Remote; the blue lights on the front of the Wii Remote
will blink.
Quickly press and release the red SYNC button on the inside of the
white flap on the front of the Wii console (picture).
When the Player LED blinking stops and stays lit, the syncing is complete. The LED
that is illuminated indicates the player number (1 through
4).
This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote
added to the system.
This is the normal cycle time and it can increase if the batteries are a bit weak. This is one of the minor issues with this camera. You should only notice this when using a flash since it has to re-charge the flash circuit, without flash the picture should retuen in a second or less.
Have had this problem before with wii sports. What I did was turn off the wii console and unplug from the power, leave for a few seconds then turn it back on when the health & safety screen comes up
Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
when you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem.
