Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-37D62U Audio Warning
In the upper right corner of the screen an box appears giving the current settings (Cable, Channel and Audio). The audio switched between different mono settings. Each time the audio changes the settings box appears. Can I lock the TV to one audio setting? Can I turn off the settings notification?
    Problem Solver:
  • 14 Answers
Usually the settings can't be turned off and the audio settings are searching for whatever is being outputted from the program itself whether mono or stereo. It is nuisance I know.
Posted on Jul 25, 2008
Audio display flashes in and out in the upper right corner
This usually happens when you are connecting a cable box or satellite tv box to the television with a coaxial cable. In order to get this to stop you have to connect the cable box or satellite tv box to the television with an RCA/composite cable. Then you will have to change inputs to the appropriate one with the input button on the television (press it repeatedly) or with the input button on the Sharp remote (press is and then scroll down with the down arrow and press enter).
If you are not using a cable box or satellite tv receiver you can try connecting a signal booster to your coaxial cable but that is not guaranteed to work.
Jul 13, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cable/Analog Icon on screen
Usually the DISPLAY Button on your TV remote will toggle through several different functions: 1 sec, 5 sec, Always on..... Press button until display on TV is off. Or see if there is an ON SCREEN DISPLAY portion in the TV Menu and turn it to off if you have not checked that already.
Apr 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LCD tv "Audio window" keeps popping up on the corner
Replacing the cable box may fix the problem. But, you're the 4th person to have this same problem with this SHARP TV MONO only audio.
Try system reset button on the back of the TV or the box.
Feb 17, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp aquos a box with mono and stereo and channel 3
Commercials are broadcast in lower quality than the programs, and it is normal for the signal to change when going to commercials. If you are watching ATSC you will notice also the video changes from HD (widescreen) to SD (normal) as well.
Jan 25, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
LC-37D62U Audio Input Issue
Reset the Audio setting to Factory setting.Should stop this.Still same problem,than ur tuner signal board is the problem.
Jan 11, 2009 | Sharp LC 37D62U 37 in. LCD HDTV
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Aug 07, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
SHARP Aquos LCD-37in
switch from 75 ohm coax to the rca jacks (red and white) even better would be coaxial digital sound (orange rca jack)or optical for the best raw 5.1 channel sound there should also be a way to use the menu to turn off notifications like that
Apr 16, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Aquos Channel Bar/audio bar
There is no factory option to stop the box from poping up every time the signal changes, which is what is happening. It has something to do with signal strength or the fact that your cable box is not set up for HD. Call your cable company to get a tech out to check your signal and set up your cable box because they do not come pre-set with HD defaults.
Jan 12, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
391 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
