Question about Vestax PDX-2000MKII PRO Turntable
Vestax pdx-2000mkiipro keeps blowing internal fuses
I turned the power on and it turned on for a second then shut off .i replaced internal 500 mil-amp fuse and when i tried to turn it on it blew the fuse. i then tried another fuse and it blew that one too.
    Sergeant:
  • 432 Answers
You see it often with guys which , when scratching , put the pitch often at full load and pressing the platter too hard. the capacitors ain't in a great shape after all those years and then the chance that the transformer gives up , is good possible. My technics mk-5 has a 60.000 uF buffer, which is ok since I also listen a lot vinyl and the noisy parts are removed/replaced, Offcourse the pus is outside the turntable.
Looking at the vestax, which I have a lot units from , but allways replaced the caps when I bought one second hand and never had
problems with the motor or transformer, where a lot of people's complain about. The motor and transformer are nothing wrong with . Often is maintenance the problem.
greetings richard
Posted on Jan 07, 2015
  • 515 Answers
You have a short in your unit, and you will need professional assistance in determining the cause. You might also want to try a different outlet. If it fails, then you'll need to bring it to a service center for repair.
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Posted on Jul 24, 2008
40 amp. fuse keeps blowing out on 2008 harley
You have a short. Check the insulation on all wiring that carries + voltage - possible that some wire may have lost insulation and is abutting some metal part shorting it out.
Aug 24, 2015 | 2008 Harley Davidson FXCWC Softail Rocker...
Why does my fuse blow out when i turn the amp on?
sounds like you have a dead short internally and unless you find and fix it will continue to blow fuses .
Aug 02, 2015 | SWR La15 Bass Combo Amplifier
Why does the fuse blow?
try a different sub first, the fuse difference is not crucial but should try to use the one recomended by manufaturer
Aug 31, 2014 | Pioneer VSX-305 Receiver
The dryer runs about 10 seconds then shut off. It
Maytag gas dryer , runs for about 15 sec. heats up , then completly shuts off , Checked thermal fuse & it was blown , replaced & it ran for about 15 sec again & blew fuse again ....help .
Apr 26, 2010 | Maytag PYE3300 Dryer
Our Panasonic CT-27HL15 set is only 4 years old and suddenly decided not to turn on. When you press the power button, it turns on for a second then makes a noise inside and shuts off. Any ideas is it worth...
I have one of those that is the same age and the 6.3 amp fuse was blown out. I replaced it with a 6 amp fuse (i could not find 6.3 nearby) and got a few more weeks use until the fuse blew out again. someone suggested i get a slow blow fuse next time.
Jun 20, 2009 | Panasonic CT-27HL15 27" TV
Powerless
There are internal fuses - or it could be a failed PSU
Aug 21, 2008 | Samsung CLP-500 Laser Printer
I have a 3 year old Panasonic CT-32HXC14J TV. It has been working fine until today. When I tried to turn it on the internal (6.3amp/125v fuse) blew. I went to get a new one and could only find a 4 pack...
Hello sjday62
It sounds as if you have a component that has changed value enough in value to cause a high current draw, but has not completely shorted out. this phrase from you "so I did a stupid thing and bypassed the internal fuse and it turned on and worked" Not as stupid as you would think because it confirms what I said above, the 6.3 amp fuse tells me that the current draw normally is about 3 amperes since the normal rule of thumb is to double the value of the current to select the type of fuse. a five amp fuse should as well as a 4 amp fuse (it's best and recommended to use the exact fuse type). Now back to your issue. I would suspect that a transformer in the power chain has developed a shorted winding, or a capacitor begun to develop a short or excessive absorption.
I would suggest that you have the set looked at by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
May 01, 2008 | Draper Cineperm 132" 1.85:1 Projector...
Protection displayed and shuts off
The protect message indicates that the output amp section has a problem. Normally this requires the replacement of the output transistors or the output amp pac. Expect the repair cost to be about $20-$60 for parts plus the local labor rate.
Dan
Mar 22, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
Hok up amp and all fuses blow on distribution block
somehow, DC car voltage has gotten to the speaker outputs of your amp! your fuses are saving your speakers from meltdown. your amp has melted down. toss it after checking with ohmeter as follows: disconnect amp completely. red wire from ohmmeter to +12Vin. black wire to SPK+. if ohms are anything below 1000 ohms, then toss it. An electrical short is equivalent to flooding your entire house with a leaky faucet. No telling what that rapid current will encounter along the amplifier section. you could get lucky and find all power MOSFETS have shorted and replace them. good luck.
May 31, 2007 | Jl Audio 500/1 Car Audio Amplifier
Vestax PDX-2000MKII PRO Turntable Logo
583 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
