Question about Frigidaire FRS23H7C Side by Side Refrigerator
JRSD209T ice dispenser
The coil auger that pushes the ice cubes out makes a loud clunk but doesn't engage and push the cubes out. Is there a linkage that can easily be checked out and repaired by owner or only by serviceman.
  • 481 Answers
Pull the auger assembly out (large plastic pan with auger in it) and make sure it does not have any ice buildup in it or on it. fully reinsert it and try it with no ice in it. if it still does not work then you may have a bad auger motor.
Posted on Jun 28, 2008
Door not dispensing ice
The auger switch in the door is bad or the auger motor is seized up/ stuck. The door switch is the problem the majority of the time. It's a simple repair. Just be careful with disassembling the plastic parts and use a flash light to find hidden screws in dark places.
Feb 07, 2014 | GE Refrigerators
Have a jennair refrigerator mdl#jfi2589aes took the ice cube storage box out to fill cooler, when i put it back in the ice cube maker will not dispense ice cubes to the storage box, ice maker is making...
Hi
This usually is because the drive on the ice box is not engaged,
1. Remove the ice box and empty it into a bowl
2. Replace the ice box and turn the auger (spiral metal inside) until it locks into the drive motor
3. Ensure the box is pushed back as far as it will go
4. Put ice back into ice box
5 Try dispensing ice again
This is a common problem as there are teeth on the back of the ice box that have to align with the drive motor in the back of the freezer
Hope this helps
Gordon
Apr 22, 2011 | Jenn-Air Refrigerators
Model FRS26R4AB5 Frigidaire ice maker. Unit makes ice but will not dispense. When engaging in-door dispenser switch, I can hear the motor come on, but the auger does not move. This occurs even with the...
pull the ice tray out, you will see a silver thing in the back that turns the auger,, push the ice dispense button ( you might have to hold the door switch in) and see if it turns, if it does you need to replace your ice tray,, if it doesn't you will need to replace the solenoid or the motor itself
Jan 24, 2011 | Frigidaire FRS26R4A Side by Side...
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE Side by Side only dispenses crushed ice
remove the ice cube tray assy, remove all the ice, save the cubes, wash the assy with warm water dry the assy, be sure the lever in the rear of this ice cube assy is moving and spring loaded, move the lever and it should snap back and return if so you know the unit is ok(the cube assy), now with the assy still out of the freezer close the freezer door and select crushed ice and push the pad where the glass normally hit to activate the ice cubes,if the operates and you here a thump and snap and hum most likely your ok,if not you could have a defective auger motor assy,but if you here all the sounds as decribed oped the freezer door and select cubed ice push actuator on despensor door with the freezer door closed, reopen and install the ice cube assy tray bucket assy,push it in firmley, and try it with some ice in the bucket you should be fine,if not replace auger motor assy..
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Only crushed ice
Pull your cube container out and push it back in.
There is a slot on the rear that the actuator arm rides in.
It has come out of position.
Mar 08, 2009 | Frigidaire FRS26R4A Side by Side...
Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
In door water and ice cube not working
Water dispenser is a simple touch switch in door energizing a solenoid water valve behind ventilation grate above refrigerator. Water tube runs down into and ends at ice dispenser chute. Should hear solenoid click at top of fridge when activate water touch switch. Can unhook discharge side of solenoid valve temporarily to prove water output. If water dispenser tube acts blocked it could be frozen where it ends-look up the hole at the bottom of refrigerator control buttons.
Ice maker is totally different system. No clicking when push ice button but ice in bulk tray may mean the simplest of malfunctions: Ice bin not pushed in the last half inch if ice auger not lined up with drive pegs. There are hidden switches behind ice bin that need to be engaged or nothing will happen in the ice maker: no auger noise, no clicking, no new ice making. Ice bin will be flush with sheet metal if it is in the right spot. Also plastic juice rack won't hang properly if ice bin not pushed in all the way.
Dec 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
Frigidaire FRS23H7C Side by Side Refrigerator Logo
115 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
